lock TC dyno instructions - in neutral?
I understand that after the pull you should put the A4 tranny into neutral, but at what point is the time to do it? That is, say I run it up to 6400-6500 rpm in 3rd (both locked in gear and TC) - as soon as I let off the throttle, do I put it into neutral? Or is it crucial to have to do so that quickly? Is it that important, or do you just wait till the rpms fall a bit?
Naturally don't want to put it neutral too soon or the rpms will get too high...
I'm trying to find out how hard it is though.
Some shops have a Tech II they use to lock the TC in third gear. I rigged my own switch that I can manually do from the center console.
Dan
In my case, the shop cannot lock the TC, so I have to do so through edit. I set the TCC lock just after it shifts into 3rd gear. Is there a way to release it at the end of the run? I was just assuming that you have to pop it in neutral - my concern is how fast do you have to do that.
Can you set the TCC release at 130 mph so that it unlocks at the top end of the 3rd gear run on the dyno? I think the release has to be lower than the lock up speed, s that wouldn't work. Unless I am wrong.
