Interesting Concept on Drivetrain Loss...
3 out / 10 in x 100%. ME = 30%. Not likely. If the ME of the Drivetrain is 85% (determined by testing), then it would be 8.5 out/10 in x 100% = 85%. You can turn an M6 drivetrain with a breaker on the trans input shaft with the drivetrain in the air. You can't generate even 1 hp that way! Even the best athletes only generate about 1/2 hp with their entire body. So it obviously doesn't take 20, 30 or 50 hp to turn the drivetrain. So the power it takes to turn the drivetrain VARIES, and it varies with power transmitted. Step up to 600 in and you will get 600 x 85% out = 510 out. In both cases the remainder of the hp will be used to heat up the drivetrain, mainly from internal friction.
If that doesn't seem right, think of what happens to drivetrain temp when you increase hp from, say, 300 to 600. You start to need additional coolers to stay in the safe range for the trans and diff. What can be causing the extra heat, except the extra power? You don't have an extra heater in there, do you?
The fallacy of your position is that you are assuming numbers, not quoting measured numbers. You're right that many scientific notions have changed over the years. They have changed because measurements did not bear out the theory. So they had to re-think the theory. In this case, detailed, careful measurements DO bear out the theory, over 200 years of measurements! ...that's just "The Way It Works". HTH
Anyways,
If im not mistaken, mechanical efficiency is formulated by dividing the "ideal" mechanical efficiency of the machine and the "actual" mechanical eficiency of the machine. (ME= IMA or De / Dr / AMA or R / Ea) Inessence, an ideal machine has 100% efficiency which unfortunately, we are no dealing with. Our system or machine is a complex machine with multiple "anchor points" and measured values of resistance, friction, distances traveled, and the single force work that drives them. ( these anchor points, gears for example, are mulitpliers of power and increase the efficiency of the machine.) AMA is calculated by dividing the resistance by the effort force. The point that is taken here is that the resistance or friction, which contributes to power loss, is a percentage that is fixed. Thus when increasing the effort force on the object, the amount of friction will increase and therefore will result in more power loss. A power loss that is dictated by a fixed percentage.
I feel, that a fixed or a slightly variable coifficient, unlike a percantage but more like a scalable whole number or variable scalar number should be used instead (e.g. 25-26hp lost through the trans.) The problem i see here is that the internals have not been changed (just the trans for example) thus resistant force or amount of friction produced is the same. When enacting more effort force on the system or trans, you running it through the same amount of friction as before you increased the power. However, since you are now increasing power, yes you will have the gears, for example, spin at a faster rate and displace more heat, which is a bi-product of the energy being enacted by your power source, and not enact any more resistance on the power see through the rest or your drivetrain. The coefficient of friction is found through measurements that dictate the force or work (energy needed) to overcome friction and produce the necesary work. (in this case, spinning the trans.)
Thus, imo, when increasing the amount of power enacted on a system (trans) the frictional force stays relatively (and i say relative because since parts do wear, there strength is being jeopardized and the amount of efficiency produced will gradual decrease, though not from the increase of power but more of the factors that we are not dealing with a perfect system with an efficiency of 100%, which is why im proposing a variable fixed scalar number and not a percentage which would enact more energy lossed than necesary.) the same, though larger amounts of heat is increased and created from the extra work being enacted, which subsiquently isnt subtracted from the power enacted since it is a bi-product of the work unless the molecular sturture of the material used have reached dangerous levels and their bonds bein to deteriate.
simply, back to my first example, you have two EXACT cans being crushed by two EXACT seperate press'. One is exhibiting 100lbs of pressue and the other is at 200lbs. The can needs approximately, and im making this up, about 50lbs of initial force to overcome its molecular structure and be crushed COMPETELY. The first will have 50lbs of "left-over" or mechanical efficiency aka ME, while the last will have 150lbs of ME. The rate of the crushing of the can is proportional to this "left-over" or ME while the heat generated is proportional to the crushing rate, frictional coefficient of the can and the "left-over" power, yet it was created by the work being enacted by the press on the can, not subtracted by the power exerted on the can (power loss). IF the heat is untolerable and will somehow jeopardize the operation, than again a cooler of some sort could be added to maintain that balance....(cough* trans cooler!
) One of the basic principles of energy was that it couldnt not be created but transfered from one form to another. However, though energy cannot be destroyed, (though im starting to feel that you can in fact destroy energy..i know, crazy, but just another of my ideas that im working on) it can surely be created in many forms due to operations, releasing of potential energies, and numerous other activities that we see everyday. (the heat created by your engine, it is a product of the engine being created by the operaton and not subtracted by the net. though again our engines are cooled to maintain a certain level molecular support and longitivity.)
With this post you are ASSUMING that the "rated" 100 shot is an actual 100 shot when in reality it probably isnt. Manufacturing tolerances, manufacters marketing etc all play a factor in what those jets actually produce. In reality you probably were making more like 150 FWHP with the "100 shot jets".
I think the driveline loss should remain fairly constant no matter how much power is add but the nitrous statement is a bad argument.
Anyways,
If im not mistaken, mechanical efficiency is formulated by ... AMA is calculated by dividing the resistance by the effort force. The point that is taken here is that the resistance or friction, which contributes to power loss, is a percentage that is fixed. Thus when increasing the effort force on the object, the amount of friction will increase and therefore will result in more power loss. A power loss that is dictated by a fixed percentage.
I feel, that a fixed or a slightly variable coifficient, unlike a percantage but more like a scalable whole number or variable scalar number should be used instead (e.g. 25-26hp lost through the trans.) The problem i see here is that the internals have not been changed (just the trans for example) thus resistant force or amount of friction produced is the same. When enacting more effort force on the system or trans, you running it through the same amount of friction as before you increased the power. ... The coefficient of friction is found through measurements that dictate the force or work (energy needed) to overcome friction and produce the necesary work. (in this case, spinning the trans.)
One of the basic principles of energy was that it couldnt not be created but transfered from one form to another. However, though energy cannot be destroyed, (though im starting to feel that you can in fact destroy energy..i know, crazy, but just another of my ideas that im working on) it can surely be created in many forms ...
Paragraph 1. My sincere congratulations! An inquiring mind is always welcome to and admired in any scientific pursuit.
Paragraph 2. I abbreviated it some because you're exactly correct and we are both saying the same thing. Put all that you said together and it comes out to: P out/P in x 100% = ME%.
Paragraph 3. Although I hear what you're saying, I don't agree. Here's why: you aren't just "spinning the trans" like a top, you're getting the trans to DO WORK. In that case the ME comes into play.
Paragraph 4. The frictional force CANNOT remain the same! The loads on the components have increased and that WILL increase the friction and the force required to overcome it.
Paragraph 5. ... Sorry, I don't believe this is a good analogy.
Paragraph 6. Well, all I can say to that is I believe you're well on the way to a perpetual motion machine! Maybe you're the one to do it after all these years. Good luck!
Finally, if what you say has merit, then I'm sure that you could propose some practical experiment to prove your theory with measured data. Maybe with a small electric motor and a miniature drivetrain of some sort? You sound like you have the skill and training to make it happen. Skeptical experimentation is the scientific method after all, isn't it?
hehe, figured I'd lighten the mood
I really believe ObZidian is sincere. I don't want to discourage anyone who might have something! I consider this a worthwhile thread. To a lot of intelligent folks, the idea of increasing loss just doesn't seem to make sense!
back to the topic though, mabe i didnt word myself correctly but my point is that fixing a percentage when concerning power loss is like a predator tune, its generic. There tons of factors or variables that contribute to not only power loss but to how we achieve or try to achieve a perfect, simple machine with 100% efficiency. I only wish that we had the proper lab and funding of course to do such an experiement ut unfortunately, we mostly spend watevet money we have left on our cars.....which isn to bad but when looked at as a net worth value, not to promising..well, not yet!!!!
A percentage to me seems like a value given to estimate the frictional coifficient of our drivetrains. I understand that it isnt a fixed value either, i had stated that im proposing a scalar value or whole number that relative to a gradual decrease of increase instead of a precentage. I feel that though you do need more power, thus more frictional force applied, to spin or create or transfer more power through the trans, for example, a fixed percentage that isnt vehicle specific isnt correct but a false value.
the only way to truly have a variable number system of whole numbers to dictate the exact power loss through our drivetrains is to have each vehicle striped down and each anchor point, gear, disc, clutch, nut, bolt, the viscosity of the fluids used, all of the thermodyanamic values for each part, all of the frictional cooiffient of each part and catagorized for its specific grouping...etc. you get my point.
again, i dont think a fixed percentage is the way to go because saying that all auto trans loss this muh (17-20 percent) and all manual trans loss this much (15-17 percent) seems wrong to me since all of this trans are purposely built by different manufactures, with differnt materials, fluids, etc. So how can one that is better equipped to handle high temp power (materials used, coolers, frictional design) loss be catagorized with another trans that is a generic "performance" built unit? It just doesnt seem right.
The analogy i used was to desrcibe the different is mechanical efficency not through friction or resistance but so the significance of wat is mechanicl eficiency; the "lft-over" power is exactly that. THe more you have left over the more efficient your system will be....
tag, you it!!!!!
I would like to hear someones argument to this from the 'fixed hp figure' camp.
I'm sure if your were to take a trans and put it on a trans dyno it would take "x" amount of power to turn it at a steady 5,000 engine rpm, but it would probably take more power to acclerate it through that rpm.
I think the specific number idea has some merit to it, but it doesnt account for acceleration and actual speed. If you add a cam to an engine and increase its peak rpm by 10% (from 5500 to just past 6000) then there is no way you would see the same # loss at peak, altough you may see it at the same rpm (both at 5500).
I guess the easiest way to figure it out would be to look at a V6 and LS1 Camaro. They have nearly identical drivelines for automatics. If the percentage thing was true the V6 would have 164 rwhp, if the # thing was true it would have the same total loss as a LS1. What would those numbers look like? Anybody have any general numbers?
Like I said, I dont think either is exactly right, but I think the percentage is far more accurate than the "given #" theory.
Again, that is the point im trying to acheive. The measuring of power increased/decreased on a dyno when mods are introduced and its apparent loss of power through different mediums.
When on a dyno, and you have swapped out you stock lid and exhaust for and aftermarket gmmg and slp lid. Prior you had done a dyno and ran your stock numbers. e.g. 292hp @ 6k. after the bolt ons, you now made e.g. 312p @ 6k. Your ME of your system or motor has now changed and is now measured at the same specific RPM as the dyno before......now, if you take it to the track, THAN you are now measuring its acceleration properties but on a dyno, you are only measuring its ME at specific rpm ranges, compared to previous pulls done.
You see, the percentage, like you said, gets you close but im a person of "exacts". That is the reason i dont have a hhp3 or predator and i own a hp tuner. I like to make sure everything is precision tuned. Also, the percentage is going to yield way to much power lose, imo. Thus imo not being close at all but further away from the truth.
From the fixed number camp, which i frequent, it simple when measuring ME at specific rpm ranges e.g. 2k-6k. Now if you increase your rpm range, you will require more power but not much. Thus the power loss through your drivetrains, will be a fixed number or very close to one. Not a percentage that will yeild more power loss as you increase engine power.
The problem is when measuring acceleration. As you spin the drivetrain faster, e.g. lower et's and higher mph in the 1320; you now require more power to spin the drivetrain becuase of its increase of fricitonal load, well, among other factors. A percentage at this point isnt correct either becuase it will yield more power loss than necesary because of the comparisons of different drivetrains into one category and the generic nature of its calculations. If anything, a formula could be introduced that would take that initial power loss than multiplied by the increase in load with the frictional coifficient at a specific speed or rate of acceleration.
just a guess....anyone have any ideas?
You did say "Now if you increase your rpm range, you will require more power but not much."
This is a contradiction to your next statement of "Thus the power loss through your drivetrains, will be a fixed number or very close to one". You said that the power loss through the drivetrain is not a fixed number by stating "you will require more power but not much". If it were a fixed number you would not "require more power".
On a dyno, your not specifically measuring acceleration rate but power or effort force. Due to the nature of a dyno and since you are simulating a run, you are gradually raising your rpm to a specific point than let it rip, thus your initial force needed will not be as great as if you were at the line and hitting the throttle with all of your might. The power needed from a stop is greater than from a roll.
Also, you are taking my words out of context, please re-read and im sure yu will still back your statement after you have read it....
I understand where you're coming from, I too like things exact. The problem in this case is, there doesn't seem to be an exact answer. The rate of acceleration of the drivetrain, viscosity losses in the tranny/rearend, torsional losses in the tranny/rearend, different weight wheels/driveshaft, etc. all play a factor in the amount of HP required to operate the drivetrain. It's a dynamic function that can't simply be calculated by adding a number to RWHP dyno numbers or adding a certain percentage to chassis dyno numbers. However, I still believe the percentage will get us closer than a fixed number. I go back to the lawnmower engine example. If you can turn/accelerate the drivetrain at a very slow rate with a 10 hp engine, but can achieve a must faster speed/rate of acceleration (of the drivetrain) with a more powerful engine, but lose more than say 9 hp to the rear wheels, it's obvious we are dealing with a much more dynamic number than saying it takes 9 HP to turn the drivetrain. A 400 hp engine is going to lose much more than 9 hp through the drivetrain.
So, if I spin my 10 hp lawnmower engine from 2k-6k, I will see the same total HP loss at the rear wheels as I would with say a 500 hp engine spinning from 2k-6k? It's pretty clear the HP loss at the rear wheels is a dynamic number. A percentage loss to the rear wheels gives you a dynamic number that changes relative to the factors that increase the HP required to operate the drivetrain, a fixed number doesn't.
initailly, no, the amount of power to spin or cause a work function on any objuect is the surpassing of its frictional coifficient. If you wish to spin the object faster or work faster, than you are now increasing the load thus lossing more power. A percentage is a generic form of doing this since there hasnt been a conrete experimentaltion with concrete results.
A fixed number isnt my point but a percentage, imo, again, isnt either. IT will yield a closer reading because it is a variant figure but not close enough because of its genericity.
building on the previous, my input:
......formula .... that would take that initial power loss, multiplied by the increase in load with the frictional coefficient (of resistance) at a specific RPM. The coefficient would be different for a static environment (dyno test) vs dynamic environment (ie drag strip -- wind resistance or drag).
I do not agree that this has not been done yet. I am sure that one or more of the major car companies have had a team of physicists and mathmaticians figure this out (probably before many of us were born) -- we just need to hunt around and find the results.
http://www.ls1.com/forums/showthread.php?t=289550
First let me apologize if this has been addressed - I didn't read the whole thread.
The more torque transmitted through the transmission, rear end, etc, the greater the friction forces and therefore the losses due to friction. This part of the equation is linear! - double the torque transmitted through the drivetrain and you double the parasitic losses due to friction.
the formula should be accomidated fo specific rom and rate of acceleration induced by power output.
