Lid and Catback -- How much HP?
Old Apr 29, 2005 | 09:41 PM
XRno1's Avatar
Default Lid and Catback -- How much HP?
If I install an SLP LMII exhaust and lid what sort of HP gain might I see at the rear wheels? I'm just looking for a rough estimate, like 5 hp or something more like 20 hp. Also, is there anything in particular wrong with the SLP lid? Should it be avoided? And are these a good pair of first modifications for as small amount of money as possible? Thanks!
Old Apr 29, 2005 | 10:46 PM
Grimes's Avatar
All lids are pretty much the same performance wise. SLP is actually a little bit nicer construction. I'd say you got maybe 15+ more rwhp.
Old Apr 29, 2005 | 10:51 PM
psykoTA's Avatar
SLP lid-better plastic, tends to rub on Camaros.....lid-9hp or so, catback-I dont know.
Old Apr 30, 2005 | 02:18 PM
99zee's Avatar
My car dynoed around 310 with the B&B and the SLP lid.
Old Apr 30, 2005 | 02:29 PM
General Jack's Avatar
You should gain about 20 hp with a lid and catback. On my old '99, I went from 297 rwhp stock to 317 with the lid and catback. Didn't dyno my '02 with before and after, but I picked up about 0.25 - 0.30 and 2.5 - 3.0 mph at the track which would indicate about 20 hp.
Old Apr 30, 2005 | 02:30 PM
Scotty-Z's Avatar
I've normally heard that a good catback and lid should get you around 20 hp to the wheels. Of course this is just a figure though, some will get more, others less. But 20 rwhp seems to be the average from what I've heard. The lid should get you about 10 hp and the catback about 15, so there's your 20 to the wheels accounting for drivetrain loss.
Old Apr 30, 2005 | 03:06 PM
XRno1's Avatar
Ok, thanks! By the way, Scotty-Z, what type of wheels are those that you have and where could I find some?
Old Apr 30, 2005 | 03:07 PM
KrazyDan's Avatar
lid and catback i dynoed at 316hp/327tq
Old Apr 30, 2005 | 03:54 PM
4mula's Avatar
on avarage, 7-8 h.p with a lid and about 10 with a catback
Old Apr 30, 2005 | 04:02 PM
WhitePheonix's Avatar
TSP Lid+Magnaflow Catback=321.7 rwhp and 335.8 rwtq on a 2000 TA
Old May 1, 2005 | 12:37 AM
Scotty-Z's Avatar
They are 17''x9.5'' powdercoated black ZR1s with a polished lip. I bought mine from AFS Wheels on Ebay, they're a great company to deal with.
Old May 1, 2005 | 08:43 AM
XRno1's Avatar
Thanks for the info!
Old May 1, 2005 | 09:54 AM
2000LS1Z28's Avatar
Since nobody seems to have a relevant before and after, here ya go...
298rwhp & 320rwtq 100% factory stock SAE corrected on Speed Inc's dynojet @ 1,200ish miles...
323rwhp & 342rwtq with ONLY the additions of a Direct-Flo intake lid and 3" GMMG cat-back system SAE corrected on the very same Speed Inc dynojet only 750 miles later (weather was also similar even though already accounted for by correction factor).
Leaning out the Air/Fuel Ratio a little with a Mass Air Flow Translator slightly bumped those #'s up to 325rwhp & 346rwtq (again, everything all the same).
This was all done to my 2002 M6 Z28 BTW...
Hope that helps and you can more than take my word for this,
Mike
Old May 1, 2005 | 12:44 PM
M6HuggerSS's Avatar
my 98Z28 did 315rwhp 325rwtq with a lid/borla....
id say stock was around 295rwhp 305rwtq.
Old May 1, 2005 | 07:09 PM
Kyle C's Avatar
297RWHP and 316RWTQ stock. Added SLP lid, Hooker Catback TB Bypass and got 324RWHP and 335RWTQ.
Old May 1, 2005 | 09:29 PM
XRno1's Avatar
Any opinions on the TSP Rumbler system? How about the TSP Lid?
Old May 1, 2005 | 09:30 PM
00formLs1's Avatar
don't have dyno numbers but have et. look at sig, this was at 4200ft thou, with a lid and bellow i was .2 faster
Old May 1, 2005 | 09:40 PM
00Z28 Camaro's Avatar
00formLs1 whats with those Track times man ?
Old May 1, 2005 | 09:45 PM
00formLs1's Avatar
4200FT above sealevel my friend, i got the formula for correcting it and at sealevel its 13.4@104.2
Old May 2, 2005 | 08:40 PM
TheBowtieboy's Avatar
I have owned two LS1's in which I dynoed with just a lid and LM.
99Z28 Hardtop M6
324 RWHP 334 RWTQ
13.2 @ 106
00 WS6 M6
326 RWHP 335 RWTQ
13.0 @ 108
This is with both cars on stock tires, stock weight, stock everything else.
Both cars only have made 3 passes down the track EVER
