locking a converter on the dyno
Old Jun 13, 2005 | 05:33 PM
LastYearZ28's Avatar
2nd gear is I have only seen 3rd gear pulls on an auto..someone please explain!!!!!!!
Old Jun 13, 2005 | 05:48 PM
Camaro ChriSS's Avatar
3rd is your 1:1 gear. I believe you can convert the numbers from 2nd gear to 3rd (I'm not positive about this), but WHY someone would force you to dyno in 2nd is silly, unless they were so concerned about their dyno that they don't want it spinning that fast (which I doubt is right). You always dyno in the 1:1 (or closest to that) gear.
Old Jun 13, 2005 | 06:30 PM
Rick@Synergy's Avatar
Originally Posted by Tech
LOL. Yeah, WTF? Tell him you want your money back. You should have dyno'd in 3rd.
Most folks who are serious about tuning spend more time on the street/strip tuning then they do on the dyno. In this case, he was asking about WOT on a dyno. Specifically, a Dynojet.
thats why I bought my dynapack. I spend alot of time tuning every car. Works great.
Rick
Old Jun 13, 2005 | 09:10 PM
nasty99WS6's Avatar
how much you lose dynoing in 2nd?
Old Jun 15, 2005 | 01:28 PM
TruDynoSports's Avatar
Actually you wouldn't loose anything. Your torque numbers would be high though because your multiplying by the transmissions 2cnd gear ratio. I have heard of other Dyno Jet owner doing this before to try to get higher numbers to show up. Dyno Jet is mostly about marketing and less about quality tuning tools. Always do power pulls in 1:1 or closest to it. Steady State tuning on the other hand can be done in any gear because all your after is the Kpa or (load) of the engine. With eddy current you can hit all of these cells in any gear. Remember, just because a shop has a dyno doesn't make them a good tuner especially if they own a Dyno Jet. All it means is they had good enough credit to buy it.
Now before anyone gets their panties in a wad, some newer Dyno Jets do have eddy current, but they are still way behind on the technology in my opinion.
Aaron-
Old Jun 15, 2005 | 01:52 PM
Aaron-
Yup. Agreed. Tuning is just what it says....tuning.
Old Jun 15, 2005 | 02:30 PM
nasty99WS6's Avatar
Aaron-
Then I guess my car is no dyno queen. 363 rwhp was what it put down on the dynojet. Bob kennedy(dynoshop owner) had guessed that it would lose around 3% being dyno'd in 2nd. so he Figured it to 374 rwhp. From what you say, it sounds like the 363 is the more reliable number. The graph looked really good though, as the car pulled all the way up to 6700 rpms before leveling out. Tell me, when you tune do you use a weld in "bung" to measure the afr? When my car was tuned about a month ago, they did not use one, they may have put one in the tailpipe? I dont know. Most accurate reading would be before the cats though, right?
Old Jun 16, 2005 | 09:02 AM
Yes for sure before CATS. If your sure that the AFR is close then at the tailpipe is ok for some WOT measurments but not for tuning, it may be a half point leaner than actual AFR. I always weld in an extra bung on any exhaust that I do, and have told my customers to do so in the future so as to be more accurate. I have several builders that bring their cars to me for tuning and most of them will now weld extra bungs in the exhaust for this purpose.
Aaron.
Old Jun 16, 2005 | 09:06 AM
Based on your numbers I would GUESS that your loaded (actual) WHP would be more like 315-320hp could be as high as 330's. Now this is due to how Dyno Jet measures hp. They simply take a know mass (rollers) and calculate against a known speed and acceleration factor to come up with a hp number. This is called inertia and I'm sure there is a better explanation with more intense math on here somewhere. One thing that some may not know and that Dyno Jet will admit to with some pressuring is that they also input a fudge factor into their computing that basically calculates bHp or hp at the flywheel. Which with some of the numbers you see makes sense. Hope this helps some.
Old Jun 16, 2005 | 09:12 AM
nasty99WS6's Avatar
315-330? Are you trying to push me over the edge? jk. I dyno'd it a month ago on a dynamics, and it put down 354 on that one.
Old Jun 18, 2005 | 03:19 PM
Ed Blown Vert's Avatar
I always lock it on the dyno when tuning. There is no way I can tune correctly unless I do. I don't think its that bad for the converter, its already locked before going WOT.
Nowt if you lock it when you are already WOT, then I can see damaging you TC.
