Temperature vs. horsepower
If we can collect some data here we can maybe come up with a HP loss due to heat theory.
Just got done dyno tuning a car and the dyno room conditions were 105*
In the winter here in South Florida, I am sure the dyno see's 50-70* operating conditions.
If you have numbers from both cold times and hot times, with the same exact tune, nothing changed on the car, please post them.
I know not many of you will have this info but if so please share...
Also they just had a guy in the other day with a Procharged built motor C6 with spray making big numbers and the guy was dynoing much lower than he did on a dynojet in GA when he said it was like 50's outside...
I will have to ask these guys if it factors in correction...I doubt it tho
So I think they have a correction factor, I just don't think it's correct. the correction factor is basically for comparrisions only as a "standard" 70* no humidty i believe and get more accurate results when mods are changed as opposed to weather afficting it. of course youll make more in cold and less in heat so the correction equals it out to a point
