LT4 385 Stroker
It's been in the car only a month, but I got it from an acquaintance who had it built and put ~6K miles on it.
385 with AFR LT4 195 heads that have additional port work.
CC306 cam
AFR rev kit
LT4 Intake ported to match heads and ported for the ASM 58 mm TB.
Drivetrain: TCI SFI certified Flexplate, TCI SSF 3500 converter, Built 4L60E, Billingsley "extreme" driveshaft, Strange 12 bolt with 3.73's and 33 spline axles.
Best pull: 432 RWHP and 468 RWTQ
Best pull that I have a graph for: 426 RWHP and 461 RWTQ
The computer lost that best run for some reason and the one we did subsequent was 426/461. The motor was hot and my battery voltage was low.
NO dyno tricks were used whatsoever. Not even a bag of ice on the intake. It put down these numbers through a very power-sucking drivetrain, so I am very happy with them. I was even forced to dyno on stock, heavy OEM rims. I did not have the right lug nuts yet to mount my lighter convo pros on the long studs that came in the 12 bolt. Lighter wheels may have allowed it to registered a little more power.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Thanks man! I have seen a number of stroker LT motors put down significantly less. Mine's not a record breaker, but I'm pleased.
CR is 11.5:1
Exhaust is JETHOT longtubes to custom true duals (H pipe, Pro flow twisters, dumping at pumpkin.)
Tell your brother I hope he's as pleased with his as I am with mine.
I did keep my NX nozzle kit on the car. My MSD window Switch is out... has a short or something. I do not want to spray without the switch working. Have too much invested to risk it.
I'm going to get a new window switch and am also looking at Nitro Dave's LT motor plate that he just came out with. It's a sweet piece.
here you go.
https://ls1tech.com/forums/lt1-lt4-modifications/396393-lt1-plate-pics.html
I consider Dave not just a vendor but also a friend. He will get you set with whatever Nitrous setup you want to go with.
I am a fan of the CC306 (my good friend works at comp) but a custom grind would yield better numbers, think more aggressive ramps, and lift IMO.
You have an Great setup and we should see more nicely done setups like the one you have. Let her rip on some Ls1's, (lol thats going to start something
) The LT4 intake seems to flow decent. It was port matched and bored out for the 58 mm TB. Granted, if I started from a clean sheet of paper, I would have done a couple things differently, but it was a really good pre-built motor at a good price, so I went that route.
Midnight madness this Saturday is going to be packed! Run it on the spray
lol.
