Big Difference in Dyno Numbers
Old Oct 24, 2005 | 01:51 PM
SnakeStomper's Avatar
Default (updated) Big Difference in Dyno Numbers
A few months ago I had a TR224 114 cam installed and dynotuned on a Dynapak system. The numbers then were 385rwhp/381rwtq.
Just this past weekend I dyno'ed on a Dynojet machine, just curious to what the difference would be. To my surprise (and everyone there) my numbers were 353rwhp/353rwtq.
So, there is about a 30HP difference (10%) between the two. From what I've heard, the difference shouldn't be that big. There was another guy there that "lost" 40hp from a Dynapak to a Dynojet.
I am going to have the shop with the Dynapak re-dyno my car to make sure nothing is wrong with it.
My question basically is: What "should" my car dyno, given my mods?
2002 Camaro SS (M6)
SLP LT
SLM Loudmouth
ASP pullies
TR224 114 cam
Whisper lid
street tune
Old Oct 24, 2005 | 04:30 PM
ls1wannabe's Avatar
anywhere from 365 to 385 at the wheels did you have it actually tuned or no
Old Oct 24, 2005 | 04:39 PM
Yep, it was tuned on a Dynapak machine.
Old Oct 28, 2005 | 08:58 AM
Nemisis's Avatar
For your mods your first numbers 385/381 seem pretty dang close to me. It looks like your only real power mods are cam/exhaust and lid, and your car should have already been making about 300rwhp stock.
Old Oct 28, 2005 | 10:49 AM
GTO_Scott's Avatar
What was the correction used on both runs, if any? (SAE, STD, none)
Old Oct 28, 2005 | 04:16 PM
SAE for both.
Yeah, my only power mods are real the cam+exhaust+tune. I'm having my car re-evaluated by the shop that did the original dyno and tune, to see if everything is ok... meaning, I didn't dyno lower due to some car issues. We'll see.
Old Nov 1, 2005 | 11:36 PM
Well, went back to the shop where I originally Dyno'd and my my #'s
were 357hp/357tq So, on the same dyno where I had seen 385/381 four months prior, I had lost 30hp.
The only thing that was apparently different from the original run, was that my PCM voltage was down about 1V. He also mentioned that the alt. and crank belts seemed somewhat loose. I will be going back next week for more evaluation.
Any opinions?
Old Nov 1, 2005 | 11:49 PM
Orange Crush 408's Avatar
WOW, Thats crazy. I wonder what could have caused that.
 Michael S. Palmer
Old Nov 2, 2005 | 01:40 AM
jbs02somws6's Avatar
What valve springs and lifters are you running? Can you post some dyno graphs comparing the runs?
Old Nov 2, 2005 | 11:52 AM
I have Comp Cams 918 Valve Springs and stock lifters.
I'll see if I can get him to email the graph of the two plots ...
Old Nov 2, 2005 | 05:04 PM
grt68goat's Avatar
How many miles are on those 918's? If you get those graphs I would like to see them.
Old Nov 2, 2005 | 06:09 PM
brad8266's Avatar
dyno numbers dont mean **** anyway, as long as nothing is wrong with the car, then why care about the lower number if the performance is no different. Take it to the track and get some timeslips. Just make sure those valve springs are OK cause they can cause power issues if they are jacked up.
