**Lil 408 update**
Old Nov 23, 2005 | 10:14 PM
destroyerSS's Avatar
Default **Lil 408 update** Dyno Sheet now!!
car made 512rwhp and 484 rwtq.
Not bad but i wanted more
So here is where i'm at.
1st} This motor has about 45 minutes of running time, Will it gain more power after a full break in? And how much
2nd} I will post a dyno sheet when i get it from TTP.
I just want to drive my 500 + hp car
Old Nov 23, 2005 | 10:26 PM
eric01ss's Avatar
hell yeah man sound good
Old Nov 23, 2005 | 10:42 PM
Wnts2Go10O's Avatar
yea you should gain some power as you break her in.
Old Nov 23, 2005 | 11:04 PM
Beast96Z's Avatar
You should gain power on the break in, but I deffinatlly would have expected more. Your torque looks awesome. It's not often that you see the TQ up there with the HP. I'm interested to see the graph and what the curve looks like.
Old Nov 23, 2005 | 11:10 PM
It's hard for me to tell also since i have not seen the dyno sheet, But i do want to see what's going on.
I know i ordered my cam as a 112lsa+ 2 and it came as a 112lsa+4 so i might go in and degree the cam back 2 degree's. I guess when i see the dyno graff i'll Know more
Old Nov 24, 2005 | 01:45 AM
Mike K.'s Avatar
Looking through your mod list I don't see cutouts. Did you dyno with them? Regardless your numbers are normal for a 408. Not super high, Not super low but right in the middle.
Old Nov 24, 2005 | 02:39 AM
Brandon Boomhauer's Avatar
not bad, but i was kinda hoping you'd get more out of it. thats a bigger cam too.
waiting for graph.
Old Nov 24, 2005 | 05:52 AM
kumar75150's Avatar
what kinda compression are u running? a lot of the people making big numbers are running more than 11.5:1 compression
 Michael S. Palmer
Old Nov 24, 2005 | 08:01 AM
Mike K. No cutout's but it's a true dual x-pipe
kumar75150 I am not sure of exact comp ratio. But i think it's about 11.3-1
maybe someone can figure it out
pistons have 2 1/2 valve reliefs and heads are milled to 69cc's
Any thoughts on if i degree back my cam 2 degree's
I think TTP set my rev limter at 6800rpm but i might ask for that to be raised cause i think with my cam size it should make power up there if i retard the cam. I too want to see the graff before i start tinkering with to many idea's
Old Nov 24, 2005 | 08:49 AM
408LS1TA's Avatar
Awesome numbers, man! Over 500 at the wheels has to be a pure animal!
Old Nov 24, 2005 | 01:08 PM
VINCE's Avatar
Shorty Director
There is nothing wrong with your numbers. They look good, but a dynograph would be good to see.
Old Nov 24, 2005 | 02:18 PM
Snapps's Avatar
I am assuming this was done on a dynojet dyno? Congrats on the killer numbers
Old Nov 24, 2005 | 02:39 PM
LSUxBlake's Avatar
Glad you finally got it done. Good #'s
Old Nov 24, 2005 | 02:53 PM
NumberOneSled's Avatar
Are the AFR's untouched or did they get worked over? Nice numbers!
Old Nov 24, 2005 | 05:22 PM
The AFR's are untouched except for they were milled to
69cc's
LSUxBlake, Any info on your car
Old Nov 24, 2005 | 07:18 PM
Beast96Z's Avatar
It seems to me that most other cars with 400+ cubes and AFR 225's are making upwards of 550 rwhp. I could understand if his cam was a smaller, emmisions friendly cam, but its really kinda large. It also looks as if he has most of the supporting mods, so I don't get it.
Old Nov 24, 2005 | 09:30 PM
obZidian's Avatar
the numbers are good numbers..there is no doubt. With a port job on the heads or maybe a higher flowing head should wake that beast right up!!!
Your cam is quite radical...its doing its job but you might need more intake flow.
But dont be discouraged.....my initial numbers were 427rwhp (A4) but that was with a STOCK ls1 intake. All you need is to get it worked out but you should be happy...which i know you are....!!!!!!
Dude, what springs are you running? i need a set of those!!!!
Old Nov 24, 2005 | 10:28 PM
kumar75150's Avatar
really?
the only car i remember that made huge numbers it that one 402 mikey at rapid motorsports did
they did another one and it made about 52x
how many 550rwhp AFR cars are there?
Old Nov 24, 2005 | 10:50 PM
JakeFusion's Avatar
Super Hulk Smash
Most 402/408s with AFR 225s with FAST 90 and 1-7/8" headers and 250 deg cams are around 515-530. I haven't seen much more than that, and he doesn't have full 1-7/8" headers.
Retarding the cam will help a bit, but your numbers are on the lower end of what's expected. Compression is probably too low for that big of a cam, especially with the 4 degrees of advance. I would have milled down to 66cc at least, but even then, that'd only be good for maybe 10rwhp.
Old Nov 24, 2005 | 11:52 PM
Mike K.'s Avatar
Originally Posted by kumar75150
really?
I was kinda wondering the same thing,
#'s are alot of times inflated to sell stuff on the internet, In my own experience destroyers 408 put down some good #'s
