Desktop Dyno/Drag
patriot stage 2 heads 300cfm intake 230cfm exhaust
230/236 .603 lift 115LSA
3 in dual exhaust, no cats and LT headers.
stock intake and t-body
d1sc intercooled procharger at 16psi
9.66 c/r, 3.91 gears in the rear
04 gto @ 3700lbs 6speed
597 tq @5000 RPM
9.72@137.5 mph. on drag radials.
234/238 113 lsa .580/.575
ETP Ti valve 240's 2.10/1.60's (11 degree)
QTP 1 7/8's w/hvmc (no cats)
TEA ported LSX 90
NW 90 TB
Mezierre EWP
FACTORY Pulley
FACTORY Muffler
Moser 9" (3.70's)
cartek clutch
steel driveshaft
raceweight 3800
NX MAF KIT (200 shot)
28" ET Drags
Valve Lift Intake Exhaust Valve Lift
.100" 73 57 .100"
.200" 152 114 .200"
.300" 210 164 .300"
.400" 266 204 .400"
.500" 312 224 .500"
.550" 327 228 .550"
423 tq @ 5000 RPM w/o/N20
666 hp @ 6500 RPM w/N20
777 tq @ 2000 RPM w/N20
11.389 @ 120.8 w/o/N20
9.648 @ 137.3 MPH w/N20
230/236 @ .050" .595/.598 lift with stock 1.7 rockers 112lsa
LS6 intake
stock compression ratio
stock heads (241)
Jethot headers (not sure what primary size is, 1 5/8 I think?), 3" ypipe
379 tq @ 5000 RPM
11.824 @116.6 MPH with a stick
11.885 @ 111.8 MPH with auto w/5000 Stall
id say by these results and the results in your sig that this is pretty accurate.
379 tq @ 5000 RPM
DD, dynosim and the other 30-50 buck programs are fun to dick around with, however as state there accuracy leaves much to be desired.
Dame should be well within the 500rwhp mark with his setup. did DD factor in the 11* heads vs the 15* stock, the high velocity merge collectors and primary length, ported intake. didnt think so. all of those have proven dyno and track gains in the real world over there "standard" counter parts. use DD to visual power curves when changing different centerlines on cams, came timing, compression, ect.
Originally Posted by Forced370GTO
370ci iron 4.030 bore x 3.622 stroke
676 hp @ 7500 RPM
595 tq @ 5000 RPM
9.743 @ 137.3 MPH
12 PSI:
677 hp @ 7500 RPM
596 tq @ 5000 RPM
9.736 @ 137.4 MPH
Thank you for your time.......I was a little curious as to see what that program spit out... but I can assure you if my car dynos 1 rwhp under 500 there's gonna be hell to pay. LOL
I mean considering there are stock cubed h/c cars that do 465 with smaller cams..... I'd like to think my goals aren't to far fetched
Thanks again
Damian
Thanks again
Damian
ohh good luck at the dyno.
597 tq @5000 RPM
676 hp @ 7500 RPM
595 tq @ 5000 RPM
9.743 @ 137.3 MPH
12 PSI:
677 hp @ 7500 RPM
596 tq @ 5000 RPM
9.736 @ 137.4 MPH
bww3588 - i dont dislike the program; i havee DD2k, Dynosim, and engine analyser. the programs are nice for comparing power curves within a given application by changing a variable or two. however as a whole the accuracy for the stated hp numbers are largely a shot in the dark. genIII stuff is especially inaccurate.
the problem with DD is assuming the programers are using the correct dimensions and specs. Download Engine analyser (search google, should be able to find the free demo) and you'll see that its worlds ahead of DD. however you'll need alot more info to input. and with anything; garbage in equals garbage out.
379 tq @ 5000 RPM
4mph=40hp, thats a lot. Id say Im pushin at least 400 to the wheels, thats at least 460bhp.Gear ratio's dont matter to me because I was trapping 119 even with the 3.42's before my 4.33's
