603/506 @ wheels... Procharged GTO
Old Jan 4, 2006 | 05:13 PM
TrakDay's Avatar
Default 603/506 @ wheels... Procharged GTO
Ok... so let's recap on a few things. I did a pulley swap a while back and never had time to dyno. I dropped 2/10s on my ET with ease and no other changes.
Setup: D1SC Procharger, Stock Bottom End, stock heads with upgraded valvetrain, 224/228 blower cam, SW LTs, Corsa Sport Exh., Spec Stg. 3 clutch, Steel Flywheel, External Fuel System, and other stuff not important to making HP.
All Pulls made to 6700RPMs
No Tune New Pulley Set...544/445 @ wheels
With no updated tune on the new pulley setup I was making 544/445 at the wheels.
Tune New Pulley Set... 577/491 @ wheels
Last week I took the Goat into the shop for a Tune finally. When we were all done it was making 577/491 with a touch of knock...
Read here for more info on that Dyno/Tune Day... http://www.ls1gto.com/forums/showthread.php?t=55648
So yesterday I dropped my car off to Julio (AlkyControl.com)
Read here for more info... http://www.ls1gto.com/forums/showthr...856#post897856
With Mathanol... 603/506 @ wheels
So I now have my AlkyControl kit installed and working great. My main goal was to get rid of the knock. before i know it we have about 3.5degrees more timing and the car is running super rich. So Formato makes a call to Julio and we pull some fuel. Now my injectors at WOT never exceed 70%!!! And The performance gains are simply amazing! If you look at my comparison graph below you can tell when the Methanol comes on as the car makes more and more power through the RPMs!!!
Look at where the Trq Curve starts... thats right guys! Starting around 400RWTrq at about 3300RPMs!!!
Green = No Methanol and Tune
Pink = Methanol and New Tune
Even More... 612/514 @ wheels
We then proceeeded to ramp up the Methanol and timing. So we made one more pass... The car was fine. I just made a game time decision that I didn't want to continue making pulls on the dyno stressing the motor too much. Jeremy and I talked about it and decided the best thing to do would be to go back to the previous tune of 603/506 and just leave it there.
Pink = Current Methanol Tune
Blue = Best Methanol Tune we backed off of
So... What do you guys think? Maybe I can squeeze a 125mph Trap out of this thing if I pull all the seats and other Misc stuff!
Props to: RevXtreme!!! From start to finish they have helped me put htis car together and done a great job so far! Thanks Dino, Kyle, and Ryan!
Old Jan 4, 2006 | 05:30 PM
FBodyPerformer's Avatar
On the 2nd graph where you added timing/meth, what the hell caused the torque to just jump up to 646!!! and then drop back down to the 5xx where it was at before, and on the 1st pull? That reminds me a supra dyno graph, but never seen it like that
Either way, nice #s!!! What have you ran at the track before? And anything else you plan on doing to the car?
Old Jan 4, 2006 | 05:33 PM
TrakDay's Avatar
Its just a spike in the dyno from a semibad connection. so just diregard the Trq spike!
My previous best was a 11.9 at 120mph. But my 60fts struggle at 1.991. I have only been down teh track 20-30 times in my life, so I am still learning!
Old Jan 4, 2006 | 11:30 PM
ls1wannabe's Avatar
What kind of a tire are you running
Old Jan 5, 2006 | 02:58 AM
bad95killer's Avatar
Stout #'s man
Ditto!!
peace
Old Jan 5, 2006 | 08:38 AM
TrakDay's Avatar
On the street I run Nitto 555 tires, not the DRs. My best 60s are with Nitto DRs, but now I am going to work on launches with the MT ET DRs I got!
Old Jan 5, 2006 | 11:11 AM
Shu's Avatar
Shu
nice numbers mick!
Old Jan 5, 2006 | 11:49 AM
Got Me SOM's Avatar
if you can't go 125 mph with 600 rear wheel horsepower then you seriously need to let someone else drive your car..
Old Jan 5, 2006 | 12:21 PM
BADSZ28's Avatar
LS2 car I take it?
Old Jan 5, 2006 | 12:49 PM
00turboT/A's Avatar
Nice numbers
Old Jan 5, 2006 | 01:26 PM
Rob's Avatar
Rob
Originally Posted by BADSZ28
LS2 car I take it?
Pretty sure Mick's car is a '04 LS1
Old Jan 5, 2006 | 02:16 PM
01_ram-air's Avatar
Awesome numbers man. Keep up the good work.
Old Jan 5, 2006 | 03:01 PM
TrakDay's Avatar
My car is an 04 LS1 GTO
I expect over 125mph believe me... And I dunno, but from everyone I have talked to launching an IRS car is completely different than Solid Rear!
Old Jan 5, 2006 | 03:13 PM
So youre part of RevX in Tampa, FL? You planning on being at the RevX/FuelSlut meet at the end of this month? Im a member of fuelslut and would LOVE to see your car in person and hear it. Looking forward to it. Nice car again!
Old Jan 5, 2006 | 04:10 PM
Got Me SOM's Avatar
its not like its rocket science!!
bring revs up, drop clutch, shift.
my car probably weighs 37-3800 lbs with me, maybe more and I make at least 100 hp less than you.. There's no excuse!
Old Jan 5, 2006 | 08:49 PM
Rob's Avatar
Rob
Actually, it is rocket science. Launching an F-Body is easy. My last two F-Bodies were an M6 96 WS6 and 89 A4 TTA. Extremely easy compared to the goat. Used to cut 1.7x routinely in the WS6 and 1.6x in the TTA. I'm stuck in the mid 1.8's in the goat.
Trust me, its no where near driving like an F-Body
Old Jan 5, 2006 | 09:31 PM
Mr 35th's Avatar
Nice numbers.....Unless you mess up on your driving you should easily hit 125mph. Nice setup.
Old Jan 5, 2006 | 09:38 PM
HTRDLNCN's Avatar
Originally Posted by Rob
trust me, its no where near driving like an F-Body
lots easier with the auto...
stab and steer.
Old Jan 5, 2006 | 09:40 PM
HTRDLNCN's Avatar
My car is an 04 LS1 GTO!
Fancy seeing you here,LOL..
Cant wait to see the beast run at the meet..
Old Jan 6, 2006 | 06:12 AM
Got Me SOM's Avatar
irs won't let you grab the 60 foot as easy for easy but don't tell me its that much harder to drive.. Get a sticky tire. The Vette guys can get it done..
my friend has a stock 05 gto and got a 12.9 out of it, the only thing he has is good tires and oh knows how to drive, this is an auto.. NO excuses!!
