Estimate the Power Ill Make on this setup!!!
Old Feb 20, 2006 | 11:43 PM
lowonair6173's Avatar
Default Estimate the Power Ill Make on this setup!!!
Im going to be building a LS1 motor using the 5.7 block and i am going to be leaving the entire lower half stock, including the connecting rods, and stock flat top pistons. I will list the other parts i am going to be using and i hope someone can give me an estimate of the power ill be making... thanks
- double roller timing chain
-Patriot 5.3 Stage III 1020 Superflow Bench 3.905 bore heads
- Vinci Cam-DUR @ .004" 284* / 290*
DUR @ .050" 222* / 228*
LIFT .551 / .551
OVERLAP 57*
LSA 115
-1.7 Roller Rockers
-Ported & Polished Oil pump
-Edelbrock performer Carb Intake/ Port matched and Polished
-Holley 950 or bigger Carb
-any other parts you need to make it more accurate please let me know. Thanks alot, Kevin
Old Feb 20, 2006 | 11:48 PM
2.055" Intake
1.60" Exhaust
-on the heads if that helps any...
