Choppy dyno readings.
1997 Camaro Z28 LT1 w/4L60E Auto trans 105K miles.
Stock longblock/trans/converter/rear end (10-bolt 3.23 gear)
Moroso CAI
Ported+Descreened MAF
TFS Elbow
Airfoil
160* T-stat
LT4 Hotcam kit
Hooker Supercomp 1 3/4" LT headers
crappy exaust shop o/r H pipe (cut on pipe, welded the other to it)
Cutout
Flowmaster Muffler
OBD I conversion tuned by Brian at PCM4LESS
As you can say, it's choppy. It seems to have a fuel issue, the pump does not prime well at all. I have to turn the key on and off several times before cranking or it takes a long time for it to get started. If I prime it several times, it fires the way it should. I was looking at the GMS 255LPH, $125 at Summit. However, I have a 90 Mustang with a EFI Holley 255lph pump and a 190LPH, which I am converting to carb, I am wondering if I can use it.
