99 Z28 A4 Dynojet Results
Old Apr 3, 2006 | 09:00 PM
cabech984's Avatar
Smile 99 Z28 A4 Dynojet Results
Here Are my numbers:
310.17 HP
325.46 FT-LB Torque
A/F Ratio: 15+
Performed @ Precision Autosports, Dayton Ohio. was on a Dynojet w/ Torque Converter Unlocked. Couldn't tune there b/c they didnt have F-Body Tuning Programs yet. Looking to get a computer tune for sure. Mods are in the Sig. Let me know what you think about the numbers and which mod route to go next.
Old Apr 3, 2006 | 09:45 PM
Magnet's Avatar
wow...thats a crazy a/f !!
Old Apr 3, 2006 | 11:04 PM
93ChevExt5.7's Avatar
Great numbers!!
Cam it (with a tune) and maybe bump the gears to 3.42 (possibly more) if you'd want.
Throw some good heads on it after that and call it a kill on almost every Mustang you grace with your presence...
Old Apr 3, 2006 | 11:33 PM
SS1875's Avatar
I was thinking the same thing, you definately need to get some tuning done. Watch those numbers get even better. Good luck
Old Apr 4, 2006 | 06:27 AM
s346k's Avatar
Originally Posted by cabech984
Here Are my numbers:A/F Ratio: 15+
i'd get a tune first and foremost, that a/f is outrageous.
then cam it!
Old Apr 4, 2006 | 08:11 AM
big dave's Avatar
Did they even have the tailpipe probe hooked up? I'm thinking that either that a/f ratio is incorrect, or that's the default number when the tailpipe emissions aren't being tested.
Old Apr 4, 2006 | 02:36 PM
cabech984's Avatar
I'm thinking of a cam just a little lazy on installing it. The A/F exhaust probe was installed and the dyno guy said a tune is in need too. There default was 18 A/F.
Old Apr 4, 2006 | 02:43 PM
98camaroLS1M6's Avatar
It's a possibility, that A/F is dangerously lean.
Old Apr 4, 2006 | 02:50 PM
Very good numbers by the way!
Old Apr 4, 2006 | 02:52 PM
GregWS6&z28's Avatar
I'm going with this guy, your dyno is right on with your mods, but I'd be very skeptical of your AF
Old Apr 4, 2006 | 08:44 PM
cabech984's Avatar
What should my A/F Ratio be at? Also, what kind of power would I see with a mild cam where I could keep my rocker arms, springs and pushrods? Or will I need to upgrade indefinatly?
Old Apr 4, 2006 | 08:46 PM
cabech984's Avatar
Im looking @ my dyno sheet and at 3500 RPM's I am at nearly a 16 A/F ratio and then it goes down to 14.5 @ a little before 4250rpms. I left my digital cam in Ohio so I cant post a picture.
