Solid AFR 205 Results (A4)....
Old Apr 9, 2006 | 11:14 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
Default Solid AFR 205 Results (A4)....
Getting the job done once again....
http://forums.corvetteforum.com/show....php?t=1360037
Ran across this well written thread on the CF.....thought these #'s were worth sharing.
Very solid increases in both HP and TQ, in light of baby cam AND an unlocked convertor. Good job DTE and congrats to the proud owner!
Old Apr 9, 2006 | 11:33 PM
ThirdGenLS1's Avatar
nice to see those heads putting down nice numbers like usual tony, you'll be getting my buisness here in the next year
Old Apr 10, 2006 | 05:47 AM
JEB99TA's Avatar
I hope to hit similar numbers when NLP dyno's my car next month. Of course,
'the humbler' at Mike's shop with prob reflect lower numbers than most dyno's, as usual. If the numbers are good, I'll post them up here.
Old Apr 10, 2006 | 06:58 AM
98SS2836's Avatar
I can't wait to see what I'm going to put down.
Old Apr 10, 2006 | 08:49 AM
gtodoug's Avatar
Those are unlocked? Holy moly that's alot of power. How can I tell by looking at a dyno graph if a pass was made unlocked or locked?
Dougie
Old Apr 10, 2006 | 10:27 AM
bad95killer's Avatar
Another satisfied customer running a set of AFR205
Damn stout #'s through an A4 & unlocked converter & Thanks for sharing Tony .
peace
Old Apr 10, 2006 | 10:53 AM
Flow Wizard
Dougie
Hey Doug...
I'm only re-iterating what the owner clearly stated (which is hopefully accurate). What I really liked about these results were the progression from almost stock, to bolt-on's and cam, to AFR's with FAST 90. The owner stated he ran ALL the testing with an unlocked converter.....keep in mind that this is probably a stock converter, which wouldn't rob as much power (on an inertia style chassis dyno) as the same combo with an aftermarket 3500 stall unit. None the less, big numbers thru an A4 and a baby cam.
I had helped someone duplicate my previous 346 combo with an A4 and a performance aftermarket converter....that build hit 440/405 on a very conservative dyno with the larger 224/228 cam and one of my ported FAST units....a stock converter on that application would have been worth a little more. I think those numbers might have been locked though....damn that was almost a year ago, maybe more....LOL
The competition is certainly heating up, but IMO, the AFR 205's are still the head of choice on a stock displacement or small stroker build....and the 225 results are also just as impressive on the 402/408 and larger platforms.
Thanks Guys,
Tony M.
Old Apr 10, 2006 | 11:02 AM
gtodoug's Avatar
Thanks Tony,
I don't know about auto's at all and how to tell the difference. Those are super stout numbers either way.
dougie
Old Apr 10, 2006 | 05:03 PM
Patrick G's Avatar
LS1 Tech Administrator
Another well-orchestrated combination of parts. High velocity ports and a cam with well-chosen valve events pumps a lot of area under the curve. Congrats to the owner! These unlocked A4 numbers rival some M6 numbers I've seen lately.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 11, 2006 | 10:46 PM
Camaro ChriSS's Avatar
Lets me know that my numbers were never a fluke.
420/418 (roughly) with a 3500 stall (unlocked) and a 224 cam. Damn those AFRs are nice. Unmilled too.
Old Apr 12, 2006 | 05:28 AM
JEB99TA's Avatar
Mine hit just under 400 rwhp unlocked with about 5 miles on a newly forged motor. That was through Cat's and Borla chambered muffler. Next dyno will be with about 3,000 miles on the motor with true dual exhaust and straight-thru Dynomax 12" bullets .... should see similar numbers ... 60cc chambers with GM MLS gaskets. That was also on probably the most conservative DynoJet in the state of Florida. I'll run it at the track and post times ... next week if the weather holds. After the track, it'll be dyno'd and will post those numbers here, as well.
Old Apr 14, 2006 | 01:56 PM
M6WS6's Avatar
Im getting dyno tuned second week of may, Im hoping my AFR's do a number on my HP and TQ graphs!!!! AFR been around for awhile and = Got my dad convinced to put a set on his 327 Chevy in is 1937 Ford., he was happy as hell with my heads! WIth that, I believe he is going with a set of AFR's as well for our new project. 1937 Fiat Topolino gasser style (can you say 29inch from wheel to wheel?21 inch wide tires........2000 lb car.....Muahahhahaha
Old Apr 14, 2006 | 08:52 PM
GTO1_OHIO's Avatar
The Vettes numbers are nice but the AFR setup on my 2004 A4 GTO beat them.
Old May 2, 2006 | 11:16 AM
chipn's Avatar
Dougie
Hi Guys,
I just found this thread. The original post referenced from corvetteforum.com is mine.
Yes, the TC was unlocked. Phil from DTE told me this originally and re-confirmed a few minutes ago via email.
The car is truly a beast now. I can break the tires free at least up to 100 mph (not enough guts to try anything faster) on Goodyear Eagle F1 Supercar (Z06) tires with lots of tread. This isn't downshifting but rather moderate accelleration just below the shift points. The only bad part is that this happens mostly when I'm not trying.
The other day I was trying a different launch technique (practicing for my next trip to the 1/4 mile track) since my tires spin too much. I squeezed down on the gas over ~2 seconds. The car pulled out quickly and I thought "great, no tire spin." I looked in my rear view mirror and saw long posi marks. Not the darkest, but my goal was not to spin the tires at all. I went back and measured and they were 43' long.
The car has gone from being quick to being a torque monster. I'm very pleased with the results.
Chip
Old May 2, 2006 | 11:21 AM
chipn's Avatar
Nice numbers - and a very nice sounding car!
I would bet that the biggest difference is your Kooks vs. my QTPs. The Tri-Y configuration might help add some low-end torque but overall these headers seem to produce less overall HP than other's I've seen (especially Kooks and LG). Live and learn I guess...
Old May 2, 2006 | 11:29 AM
BAIN's Avatar
I'm not saying anyone is a lier, but that dyno graph doesn't look like an unlocked converter graph. What size and brand stall is it? If it were unlocked the TQ would have flashed/peaked sooner and then fell off. Notice how the TQ rises then peaks and starts to fall as a locked converter does.
Old May 2, 2006 | 11:48 AM
s346k's Avatar
seeing the 115 lsa indicates to me that it would be a fairly small stall, and probably wouldn't flash like our 4k+ monsters
Old May 2, 2006 | 12:37 PM
Dynotech Engineering's Avatar
The T.C. is completely stock and final pulls were made with the A4 trans. held in a 1:1 ratio, 3rd.
Old May 2, 2006 | 01:21 PM
BAIN's Avatar
Ok it kinda makes since with the stock stall, but then again why would anyone have a stock stall
