How much rwhp is header coating worth?
Old Apr 17, 2006 | 11:48 AM
pHEnomIC's Avatar
Default How much rwhp is header coating worth?
Anyone have a valid dyno testing comparing coated to uncoated headers without any other variables?
Is there really a performance benefit in getting coated headers as opposed to uncoated.
I am referring to longtubes here.
Old Apr 17, 2006 | 12:03 PM
NviouSS's Avatar
the coating only helps to prevent rust.
Old Apr 17, 2006 | 05:30 PM
SSDude's Avatar
No, the coating also helps to keep the temperature down in the engine compartment.
Old Apr 17, 2006 | 06:17 PM
pHEnomIC's Avatar
I am hearing a lot of conflicting ideas here. IDK
Old Apr 17, 2006 | 06:39 PM
98SS2836's Avatar
very little benefit ie anti rust cooler under hood temps. I don't believe it will speed up the exhaust velocity any so I would say little or no power increase but I have no real world data.
Old Apr 17, 2006 | 07:00 PM
gollum's Avatar
Wrapping headers is said to improve exhaust velocity and scavaging. Maybe ceramic coating them helps some but to a smaller degree.
Old Apr 18, 2006 | 09:55 AM
Detroitmuscle's Avatar
I doubt you'd see any gains at all.
Old Apr 18, 2006 | 10:08 AM
vodas00ss's Avatar
wow...
Old Apr 18, 2006 | 10:40 AM
ls1wannabe's Avatar
They make your car's engine look good.
Old Apr 18, 2006 | 10:48 AM
JerseyLS1TA's Avatar
I highly doubt you'll see any gains from it, but they do keep engine bay temps down and prevent rusting.
Old Apr 18, 2006 | 11:06 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I saw about 50 RWHP out of it - roughly...
Old Apr 18, 2006 | 11:33 AM
bad95killer's Avatar
it's all about temp. & anti rust .
peace
Old Apr 18, 2006 | 11:59 AM
SHINER's Avatar
hahaha
Old Apr 18, 2006 | 12:13 PM
HartAttack's Avatar
I GAINED 11.23 hp switching from non-coated lt's to ported manifolds with two heat shields......
true story
Old Apr 18, 2006 | 12:16 PM
HartAttack's Avatar
but really the only thing would be Intake air temp reductions over regular coated headers..how much off i am not sure....maybe 5-10 degrees?
Old Apr 20, 2006 | 12:00 AM
SSDude's Avatar
It may not be wise to coat stainless steel headers (I am not talking about 409 mild steel).
http://www.z06vette.com/forums/showt...ing#post717611
