Adding a 90/90 set up...
Old Jun 19, 2006 | 04:43 PM
01Z0H6's Avatar
Default Adding a 90/90 set up...
Your predictions..?
A4, 3500 stall (Yank),323's,28.8FI's,232/235 .595 .601 114,Ported LS6 heads,pulley,Pacesetters,True duals( out the back),160deg t-stat,HP tuners..
Here are my current numbers...
[IMG][/IMG]
Thanks... I'll post up when i get it on...
Oh, & the 90 intake has been ported... ( same guy that did my heads)
Old Jun 19, 2006 | 06:30 PM
CNB's Avatar
CNB
5 in the midrange and 10-15 up top.
Old Jun 19, 2006 | 08:49 PM
01Z0H6's Avatar
Damn Mike i did not want you to know tili did a drive bye on that FRC...
That's the only way i'd run with you... Gotta sneak up..
I can't wait... having it painted and everything...
PM me with your cell # again... we'll do lunch..
Old Jun 19, 2006 | 08:53 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
The gains are typically around 20hp and torque. You should be right on par.
Old Jun 19, 2006 | 10:57 PM
CNB's Avatar
CNB
Pull the old ricer flyby? Sent PM.
Old Jun 20, 2006 | 08:49 AM
Detroitmuscle's Avatar
Wow those are great numbers how do you like that cam and what kind of track times do you pull with that setup?
Old Jun 20, 2006 | 04:08 PM
01Z0H6's Avatar
Brother i have not even had it to the track yet.. The cam is awesome! The custom grind is from one of the local DFW shops here.. ( RPM4)..
I'll post gains in a week or so... I'll have the 90/90 this Friday!
Still contemplating whether to step up to the 85mm maf, lid.. or just start out with my stock maf,MTI lid... I'll defiantely step up @ some point.. Maybe a Z06 maf...?
Thanks for the comments... 7 out of 117....? guess alot of guys could care less...
