Stock LS6 heads results inside...
Old Aug 5, 2006 | 08:44 PM
dug's Avatar
dug
Very solid numbers. Think youd pick up any power with a similar cam on X-ER lobes? (.581 lift vs. .566)
Old Aug 9, 2006 | 07:56 PM
Krab's Avatar
Thanks. I'm pretty sure I'd see a small gain with a similar (224/224) XER lobe cam, but I don't think it would be significant enough to justify the work of a swap.
Old Aug 10, 2006 | 04:33 AM
dug's Avatar
dug
Yeah, itd be foolish to change the cam for just more lift. I was thinking if someone wanted to duplicate your combination.
You have a nice setup for a daily driver.
Old Jul 27, 2007 | 03:11 AM
mazdized's Avatar
Default did not feel much....
Nice gain... I just did mine from stock 241 to 243 with same factory MLS gasket, but I decked the 243s .015 inch. and also did a valve job. 224/224 .581 112 lsa cam and the motor sees 7k rpm all the time. Did not really feel any gain from driving..... but may be be a 20-30 hp gain with a motor already has 390 plus will not be that noticable.
Old Jul 27, 2007 | 05:14 PM
mudflap1989's Avatar
Resurrecting one from the dead, huh?
Old Jul 27, 2007 | 06:28 PM
98camaroLS1M6's Avatar
nice gains!
Old Jul 31, 2007 | 10:04 PM
Jrp1978's Avatar
dude that is awsome # for ls6 stockers . i also heard 15 20 hp max . Nice!!!!!!!
Old Aug 1, 2007 | 01:53 AM
cantdrv65's Avatar
Post
Add another 25rwhp by going with PRC CNC Ls6 heads....thats exactly what my Z06 gained going from the stock 243s to ported....same cam, gaskets etc...
Old Aug 1, 2007 | 09:49 AM
KONG's Avatar
Originally Posted by Krab
I had been wanting to do this to my car for a while, and finally took the plunge. My mods before the heads were:
TR224 cam (112 lsa)
LS6 intake
Shaner S2 throttle body
Lid
ASP pulley
Jet-Hot LT's (w/ ORY)
SLP D/D catback (no cut-out)
With these mods, I put down 375/369 (rwhp/rwtq). I had also put down 376/376 on a previous dyno with the same mods. This was also using the stock injectors (26.6# I believe), which were at 98% duty cycle. These runs were made in 92.43 degree temps.
Last week, I added a set of untouched LS6 heads with the light weight valves, upgraded to SVO 30# injectors and used stock 6.0L MLS headgaskets. I went to tune my car a while ago and my new numbers are 411/401 (rwhp/rwtq)! These runs were made in 100.9 degree temps and my A/F was ~13. A gain of 35 hp and 25 lb/ft to the wheels. I was told that I would gain 20-25 rwhp, so I'm pretty happy with the results.
Keep in mind, my car had 853 heads on before, which aren't known to be the best flowing. I just wanted to post this for any guys who were curious to know the results of adding stock, untouched LS6 heads to their cammed LS1's. Any feedback is appreciated.
I'd post up the dyno sheet, but haven't scanned it yet. I didn't get a copy of the 411/401 run, but have one that reads 411/396. I'll post it up when I get a chance to scan it.
Nice gains..is it a stock 10 bolt car? I run stock ls6 heads on my T/A. .040 cometic head gasket, ls6 intake, full bolt-ons and it layed down 424/398 through a 9inch. How were your injectors maxed out? I run a similar set-up and a bigger cam(228/232) and my duty cycle is mid 60% range. Who knows??
Old Aug 1, 2007 | 10:16 AM
Black FormulaLs1's Avatar
am looking to go with a VERy similar set up but with the Vindicator cam and LS6 heads...not sure which head gasket to go with but i heaerd of PTV clearance issues with the Vindicator and stock LS6 heads...any help?
Old Aug 1, 2007 | 11:32 AM
PewterScreaminMach's Avatar
Wow, this is an old thread.
I've tried a few exhaust set-ups, including having a cut-out and have just come to like the SLP D/D. I don't want to cut it up so I can install a cut-out, so I'll just live without the hp it's costing me.
Don't think I've ever heard that one before from a car guy, and will likely never hear it again, haha .
Old Aug 1, 2007 | 02:23 PM
  #32
gollum's Avatar
Originally Posted by bad95killer
I completey agreed with ya man a set of 0.45 cometic gaskets would work perfectly with his setup
peace
I thought the .040 Cometic was the most commonly used for good quench. I know AFR recommends the .040
Old Aug 6, 2007 | 06:13 PM
  #33
HioSSilver's Avatar
i love to see these kinds of comparisons. I have stock ls6 heads also, actually it's a stock ls6 crate engine with bolt-ons. Good #s. There has been a many ported h/c cars not make that.
Old Sep 9, 2007 | 11:20 AM
  #34
98SS1LWEE's Avatar
Yeah, wow, i'm gald someone brought this back. Just bought some 243's form another member to replace my 806's with my t-rex cam. I also need gaskets and bolts for that matter, but scared about PTV Clearance with my cam. Any suggestions. I'm not looking to go extensive, jsut need soem good sealing gaskets with a good amount of thickness. I'm gaining a good bit of compression and flow jsut off the swap. Someday they'll get P&P but for now going on as stock
Old Sep 9, 2007 | 11:49 AM
  #35
allngn_c5's Avatar
I would have used .040 cometics to boost up the compression and bump up my torque numbers quite a bit. At any rate if you have a head gasket failure, you know what to use next time. Cometic .040
Old Sep 12, 2007 | 02:17 PM
  #36
PunkNPonys's Avatar
Those were some awesome gains man. I think you just sold me on a set. Where did you get your set of LS6 heads? Where can i just get a stock set of LS6 heads for a good price? I have been debating on whether to get some heads or N2O but now seeing this thread and also researching it i think i am sold on getting LS6 heads. I wasnt aware that the 853s flowed worse then the 241s.
Old Sep 14, 2007 | 06:59 PM
  #37
davered00ss's Avatar
Moderator
I've seen a lot of cometics leak. I did not want to take the chance, so I stayed with stock GM gaskets.
Old Sep 14, 2007 | 08:26 PM
  #38
allngn_c5's Avatar
When I swapped heads from stock to AFR's the cometics did leak. Then the gms' were put on and held but later failed. Cometics are on now and working great. No complaints.
