Fastest cam only LS1 contender!
Basically, if he's got a converter with a 2.5 stall torque ratio, the converter will multiply the engine torque 2.5 times at the initial hit. The only happens right at the launch, then the torque will fall as the speed of the turbine approaches the speed of the tranny output shaft. Once coupled up (you can see it at 5800 rpm), the torque curve will more closely mirror a manual transmission. Should be a lethal combination! Good luck!
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Kooks 1 7/8" w/ a Magnaflow on each collector
FAST 90mm intake w/ TPIS 90mm TB
ASP pulley w/ short belt
Granatelli 85mm MAF
Lid with my own custom "SUX2BU" ram air
T rex cam w/ Patriot golds shimmed .045" & 7.425 Comp pushrods
Turbo action 8" 5300 stall
spooled, 4.10ed, 31 spline axled 8.8 rear end
28x10.5 ET Drags on 15x 10 Draglites.
peace
That does make sense..My experience with dynos are a little old school, use an engine dyno, pick a converter, drop it all in the car and then head to the track.
Here's my graph if you're curious. As you can see, there is no tq spike. http://img.photobucket.com/albums/v6.../Dyno_2006.jpg
DOESNTSUCK2BU, which lid are you using? Also, I'm a little surprised those 1-7/8 headers didn't hurt you. What's your raceweight again? I predict low low 10's.
I'm keeping it in daily driver trim. the only thing i take out at the track are the floor mats, the rear hatch divider and whatevers in the trunk(i leave the passenger seat and harness in).
It should be around 2900-2950 lbs.
http://img.photobucket.com/albums/v5.../DynoSheet.jpg
an unlocked stall will do that
But let's see what that thing will do in the real world.
Please keep us posted.
This is definitely one of the more interesting things going on here at this time!!
