lost 58hp going a4.
Old Oct 1, 2006 | 11:10 PM
SPRAYED 01's Avatar
Default lost 58hp going a4.
Just got the car back with the m6 to a4 conversion. Only put down 370 compared to 428 with the m6. This was with an unlocked converter and a 4000 yank stall. Does this seem right. What would have done locked??
Old Oct 2, 2006 | 06:21 AM
300bhp/ton's Avatar
Is it the same dyno and are both numbers corrected to SAE?
It could well be right, but there's likely to be some varience anyhow. Even without any changes you could easily have seen 10rwhp variance in numbers.
Also you haven't lost any HP at all. The engine is just as powerful, dirvetrain loss has increased but it's being used differently. Aftermarket stalls are not as efficent as stock ones, and being unlocked I can well believe the numbers are not far off.
Old Oct 2, 2006 | 09:20 AM
Slowhawk's Avatar
LS1Tech Sponsor
You didn't loose anything. They are just Dyno #'s.
Old Oct 2, 2006 | 02:30 PM
mike c.'s Avatar
go to the track....it may e.t better and that is the point,right.
Old Oct 2, 2006 | 02:31 PM
landstuhltaylor's Avatar
update your sig
Old Oct 2, 2006 | 05:19 PM
firebird6786's Avatar
automatics suck on the dyno.
Old Oct 2, 2006 | 07:27 PM
gruntwork's Avatar
Check out the numbers in my sig. Our setups are similar only I have an auto and I put down 409 HP LOCKED. Unlocked I could only guess how low, maybe 380, 385. Auto cars usually post locked numbers because thats how we tune them, locked. Maybe locked you'd dyno around 395, 400.
Also on another note, you might consider also that locked A4 #'s compared to a same setup M6 #'s are roughly 20-25 HP less. Hope this helps.
Old Oct 2, 2006 | 07:35 PM
john563's Avatar
Dont get too caught up in numbers with an A4.My car only puts down 355rwhp and in a street race stick shift guys are always telling me how much more they put down on the dyno,but guess what happens when that light turns green.Im long gone
 Michael S. Palmer
Old Oct 2, 2006 | 07:49 PM
gruntwork's Avatar
Damn straight.
Old Oct 2, 2006 | 08:32 PM
AINT SKEERED's Avatar
Those guy's just cant drive
Old Oct 2, 2006 | 10:05 PM
SPRAYED 01's Avatar
Im not really to concerned about these numbers. Im a believer that the auto do better at the track and thats all im really concered about. Just thought i would share my results. It was on the same dyno. Its funny to see the faces on people when they ask me if i put an auto in to make more power and i tell them i lost almost 60 horse. They are so confused. The stall is a blast to drive and i cant wait to hit the track on saturday.
Old Oct 3, 2006 | 06:46 AM
Charles Cyrus's Avatar
When I went from M6 to A3, I lost bout 35 hp, but picked up a solid 4 tenths in the 1/4. But I could not drive a stick for nothing!
Old Oct 3, 2006 | 11:44 AM
dynocar's Avatar
A few years ago we had an LT1 Turbo w/6 spd, had approx 575HP, went to high stall auto, had approx 474HP on our Mustang Dyno. However, his "force" pulling on the dyno straps increased approx 400 Lbs at given MPHs due to the drivetrain's TQ multiplication at the rear axle due to the higher stall.
Old Oct 3, 2006 | 12:20 PM
mike c.'s Avatar
JOHN563-i know what happens when the light turns green when i'm against an auto.....i usually win. in fact i cant remember my last loss,it's been two years or so. i out 60 foot almost every a4 i'm against,my best so far is a 1.34.
AINTSKEERED-right on bro!
Old Oct 3, 2006 | 06:20 PM
engineermike's Avatar
Some turbo mustang guy lost 220 rwhp when he swapped to an A3.
Old Oct 4, 2006 | 08:38 AM
TeEnAgE pHeNoM's Avatar
Even though I have a 6-speed, I will say this....NO ONE can out shift an automatic! However 6-speeds are a lot more fun though, especially if you have a 12-bolt or 9".
Old Oct 4, 2006 | 08:41 AM
Quick1998Z28's Avatar
if you are still running 11s with over 500 RWHP you are one of those guys
