220/220 dyno numbers
Old Nov 5, 2006 | 12:36 AM
amit's Avatar
Default 220/220 dyno numbers
does anyone have this cam and has dynoed it??
i have no clue what i should put down with the mods in my sig.
370-380?
Old Nov 5, 2006 | 07:35 AM
offaxis's Avatar
I had that cam a while back. You should be right around 380 with your m6 car..
Old Nov 5, 2006 | 12:38 PM
amit's Avatar
i hope so i did a search and i was NOT impressed.
Old Nov 5, 2006 | 01:04 PM
66deuce's Avatar
i've seen a couple of 375-380hp dynos from the 220.i made 355rwhp,unlocked with the mods in my sig.but don't look at just the peak numbers.that cam makes a broad powerband that can get a car moving down the track as quick as some bigger cams.i love the streetability of it as well..
Old Nov 6, 2006 | 04:50 PM
Camaro Rick's Avatar
I just made a post about getting back from the dyno earlier...
Mods in sig, Made 373/360 untuned. They could only get it up to 378/367 after due to the injecters limiting how much fuel she could drink. They guy said I would be somewhere around 400 after 30#ers.
Old Nov 7, 2006 | 12:44 AM
amit's Avatar
very nice. thanks
Old Nov 7, 2006 | 01:08 AM
It's pretty cool. We've got fairly similar cars. The only thing HP oriented I have on you are the 243's which clearly aren't the most serious heads to throw on. But then again, you have a pulley on me. I wouldn't be surprised if we both put down the same numbers. Nice car btw. And how are you liking your 220/220? I'm in love with mine thus far. I may want to upgrade in the future. But the thing hauls(to me) pretty well for now.
Old Nov 7, 2006 | 06:04 AM
Slowhawk's Avatar
LS1Tech Sponsor
I've seen 355-375 with all the bolt-ons.
Old Nov 8, 2006 | 01:34 AM
amit's Avatar
i like the cam allot.. i bought it cuase i wanted something to idle stock yet perform btter then teh ls6 cam.
Old Nov 8, 2006 | 04:15 AM
dug's Avatar
dug
220 cams never dyno well. Same with 228 cams
Old Nov 8, 2006 | 11:52 AM
I bought mine for the same reason.
And what? if they don't dyno well, howcome I've put down almost if not as much as some guys with ls6 heads/intake and a 224?
I was shocked to see 373/360 untuned on the first pull. Wait until I get some injecters and another few pulls. You won't be saying the 220 doesn't dyno well. And I've also got to put my ported TB back on. That should help a bit too.
Old Nov 8, 2006 | 12:11 PM
Slowhawk's Avatar
LS1Tech Sponsor
You have LS6 heads which raise the compression
I've done built 220 Cam cars that put out over 425rwhp but they had real good compression from LS6 heads
Old Nov 9, 2006 | 10:54 AM
This is true.
Since they were damaged when I received them, Golen motor shop shaved about 1 thousandth of an inch off the base. Chad Golen stated it might have raised my compression a tad. So. Neat stuff.
Old Nov 9, 2006 | 04:40 PM
Spellbound's Avatar
With a thunder 220/220 114, I was right around 380ish with LS6 heads, and most of the bolt ons. I enjoyed the hell out of that cam!
Old Nov 10, 2006 | 01:07 AM
amit's Avatar
ok now im scared of dynoing this thing! lol
god if i ge 350whp im gonna shoot myself
Old Nov 12, 2006 | 01:36 PM
00T\A's Avatar
I run a 221/221 .558/.558 on a 114 #'s in sig.
Old Nov 15, 2006 | 09:47 PM
98camaroLS1M6's Avatar
Not all about the peak numbers, this cam make strong torque, good street cam.
