some advice, please... !!!
Old Nov 27, 2006 | 01:25 PM
misho911's Avatar
Default some advice, please... !!!
hi...
I makes a dyno for my trans am 99
and i got 382 horse power, 364 torque, so how is it???
by the way my bolts on is:
Headers LT, stock Y exhaust with cut after Y, Intake filter, BBK throttle body 80mm, Manifold Intake LS6, Injectors 30 lb, Fuel Pump in tank 255 lb, ASP Pully, Clutch & Flywheel SPEC Stage 4, MCLoad Master, camshaft extreme energy from CompCams (605,609-238,240-112) with kit Camshaft, Ring & Pinion 3.73 and tunning by HP Tuners
and in this time i well make heads Patriot Stage 3, so what your expect? how much i get a horse power and torque and modiy the tunnig???????
Old Nov 27, 2006 | 01:31 PM
prostock_bigblock's Avatar
numbers seams low to me. how does the car run? do u have any graph? heads will do add some good power but u need to work on your low numbers first there must be something wrong.
have u checked your BBK tb if it opens all the way?
where r u located by the way?
Old Nov 29, 2006 | 03:20 PM
misho911's Avatar
First of all thanks to answer me...
1- It's run well, and i got in drag race 12.4@116.25.
2- yes, but this graph is before i installed the diff. 3.73
3- the BBK is open 100%
4- my location is in saudi arabia in jeddah...
Old Nov 29, 2006 | 03:50 PM
you trap speed seems low to for a decent size cam, what was ur 60' ? it would be great if u can post the graph.
Old Nov 30, 2006 | 02:49 PM
misho911's Avatar
My 60 Foot is 1.887
Old Nov 30, 2006 | 05:25 PM
vince3's Avatar
exhaust is hurting you. that is why your numbers are low.
you also didnt state what brand of headers or if you have a lid.
Old Nov 30, 2006 | 06:26 PM
rickyracer25's Avatar
What was you air to fuel ratio, and also please get us a graph. Like vince said your exhaust is killing you, get a true-dual system. Also are you a M6 or a A4 this will affect your numbers greatly
Old Dec 3, 2006 | 10:09 AM
misho911's Avatar
Hi again....
Now i makes an exhaust dual system (2 line to end) with true x-pipe maganflow and 2 mufflers maganflow with above bolts on, and i will make a run on dyno as soon as possiable, so what your expect to get on dyno and what is the number in drag?????
 Michael S. Palmer
Old Dec 3, 2006 | 12:22 PM
Originally Posted by misho911
Hi again....
you will probably run 12.2-12.3 and will gain around 10-15rwhp on the dyno.
Old Dec 10, 2006 | 12:55 PM
misho911's Avatar
Hi ... again
I got in drag 12.03 and speed 191 km, that is before I tune on dyno after I makes heads stage 3 patriot, so what is you comments?
Old Dec 10, 2006 | 01:17 PM
cav101's Avatar
just trying to clarify, the 12.03 was with the patriot stage 3's on?, without tuning?
Old Dec 12, 2006 | 10:23 AM
misho911's Avatar
first: the time 12.03 with Patriot stage 3 and with modifyed tuning before a makes the heads.
second: i have stroker 383 ci 10.0 compression i didn't use it yet it cames with that heads 10.5 compression so what is your advice for make my perfomance better?
Old Dec 12, 2006 | 10:39 AM
I dont get it what is ur current engine displacement? with 12.03 run was that on 383ci or stock engine?
Old Dec 12, 2006 | 11:09 AM
misho911's Avatar
is with stock engine stock cubic inch and above bolts on
Old Dec 12, 2006 | 11:24 AM
misho911's Avatar
if i want to buy a complete diff from rotor to rotor which is best for street/strip?
(12 bolts or 9 bolts)
And from which website i can a full diff like this???????
