Final CT Corvette 1997 C5 H/C #'s inside
Final #'s 412rwhp/394 tq corrected. 441/422 uncorrected.
1997 M6/120,000 miles
Texas Speed CNC'd LS6 Stg1 heads
ARP head studs
GM MLS head gaskets
Comp Cam 228/232 custom grind cam
TSP/PRC dual springs, titanium retainers, new seals, seats
TSP/Trend hardened pushrods
LS7 lifters
LS2 timing chain
LS6 Oil Pump
Powerbond UD pulley
97/99 valvecover/coilpack conversion
Textralia OZ700 clutch/New LS6 slave/master
Some decent gains under the curve
Drivability is near stock, lots of fun on the street with 350ft lbs available on tap down low just a bit off idle. Car didn't peak like it should have. Many things are possible. 120k on the motor is one of the top theories, another is a restriction in the 1.75 headers/2.5" catback, lastly the intake (Ls6 vs FAST). I'm not going to chase my goals with mods or tuning. I was hoping for ~430-450 rwhp and ended up with and honest 412. 485hp at the crank is good enough for me. Chasing that last 20-40hp could cost me hundreds or even thousands. Not worth it.
As for the power vs mods it's respectable.My dyno is no queen.We've had numerous so called big hp cars on it that dyno'd alot lower than the previous shop's dyno spit out.The heads on average are good for 30hp,so that leaves 50hp for the Cam.Pretty good,but a free flow exhaust would probly help in the # department but it would be too loud for this case.
all i can say is congrats!
try to dyno it back with a cutout if u had the chance in the future.
Congrats,, the numbers look good to me. I doing final assembly on a similar motor and I’m hoping for similar numbers.
Can I ask about your cam specs and SCR/DCR??
Thanks!!
Everyone I see is putting down ~430-450 with my combo...but there is one factor that Slowhawk and I didn't rule out last night. The new part is going on today and we'll see if that improves things.
Okay, I serious doubt it is the exhaust then. The intake also is not holding you back to bad. I know the Z06 Ti and the B&B bullets had no difference on my car's dyno performance. It layed down the same number with both. My car is making 452 rwhp H/C setup with the Ls6 intake. Let us know how the new part does.
Agreed the peak hp is low, now its just finding out WHY. With the torque so high, it makes me think that my bottom end is pretty tight. I would expect a torque loss with compression problems.
I wonder...I have z06 screens in front of my vararam...I wonder if that's causing enough restriction/turbulence that it loses peak hp....hmmm. Those are some pretty thick wires. I'll have to gtech it and see.
I had the same cam on a 114 (G5x1) and stage 2.5 ls6 heads.
i had the tpis headers and catted xpipe which hurt the tq some.
i might have got more but the 3.90 gears and the ls7 clutch and flywheel might have took 10hp away.
im sure it drives great.
We were dynoing at 12.9:1 and the car was still blowing black smoke...showing that it was rich. If the tailpipe AFR was 12.9...one bank could have been 13.5 and the other was 12.6! Now you see how that might make a difference at high rpm!
When you say "a little richer" do you mean >.01 volts or more than .3% LTFT? Mine were .880 and .930 at WOT, that's too much of a difference.
1. what lobes are you using?
2. what is your lsa and icl?
3. and why the ls6 heads over say 5.3's?
I went with the LS6's over the 5.3's because of cost and because I would have needed to have the 5.3's milled to get the right compression and the chamber supposedly isn't a good as the Ls6 chamber. I haven't seen people putting down MORE hp/tq with the same setup and ported 5.3's.....
So what you are saying is that once you got the car dialed in the LTFT on one side went positive?
