408 dyno graph
Old Dec 17, 2006 | 10:35 PM
marine02ss's Avatar
Default 408 dyno graph
I dynoed again no AFR ratio reading,Im kinda wondering how it will change with the 238/249 Patrick G suggested,I want more TQ down low without suffering too much topend
http://i120.photobucket.com/albums/o...s/100_0192.jpg
Old Dec 17, 2006 | 10:58 PM
gtovan's Avatar
What is your static compression ratio and the intake centerline on the cam you have now? I'm assuming it is a TSP Texas Giant using a XE-R intake lobe.
Old Dec 17, 2006 | 11:37 PM
bad95killer's Avatar
i can't tell much on that graph but isn't (545rwhp/455rwtq) ????!
peace
Old Dec 18, 2006 | 12:09 AM
gtodoug's Avatar
looks like 513/483
Old Dec 18, 2006 | 12:14 AM
marine02ss's Avatar
Its 518hp 481ft/lbs,its the TX giant 114,static compression is roughly 11.8cr.Single y-pipe thru bullet muffler.I want to install a dual bullet setup just to see if it will help on the #s I want better ET's.Ill see if the smaller cam will get me better low end TQ
Old Dec 18, 2006 | 01:45 AM
1fastTransAm's Avatar
From: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
NIce those are the numbers I am looking for as long as I can get mine tuned right. Looks like we have very similar set ups.
Old Dec 18, 2006 | 03:46 PM
gtovan's Avatar
You have roughly the same SCR as my 455 (11.9). I am switching cams from a 243/243 LSK lobe 114 LSA +0 to a 243/247 LSK 110 LSA+3 ( 7 degrees sooner intake valve close than current) in order to pick up torque w/o killing the top end. It should be finished soon and I will get you the results.
Old Dec 18, 2006 | 04:21 PM
LostCauseZ06's Avatar
go with a bigger cam, they are way funner haha when are you racing under 3k anyways??
Old Dec 18, 2006 | 06:08 PM
Red99TA's Avatar
gtovan - you have a siiiiiiiiick pair of rides!!!
