When tuning conservative...
Old Jan 28, 2007 | 02:43 PM
mahhddgtp's Avatar
Default When tuning conservative...
When it comes to a conservative tune, do people generally make a dynorun with the highest numbers without any knock, then pull it back a little (the timing)? Or do they typically just use the highest yielded numbers with zero knock...
The reason I ask is because don't people typically see more knock on the dyno than they do on the street? If you saw 1 or 2 degrees, couldn't you leave that tune and have the possibility of not having any on the street (I understand this would be aggressive in doing so).
Old Jan 28, 2007 | 04:37 PM
Patrick G's Avatar
LS1 Tech Administrator
There is less load on an inertia dyno (like a Dynojet), but around the same load on an Eddy Current dyno like Mustang. With less load, you need to tune more conservatively because if it knocks on the dyno, then chances are good that it will knock even more on the street (more load). Best to keep adding timing until the motor stops gaining power. If the motor stops gaining power at 28 degrees and flatlines in power until 34 degrees, it's best to set it to the lowest timing where you made the best power. In this example it would be 28 degrees. Give the motor what it needs and no more. Same with air fuel ratio. Best to err on the rich side. If it makes the same power between 12.6-12.8:1 A/F ratio, it's best to set it to 12.6:1. Better safe than sorry.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 1, 2007 | 05:55 PM
mahhddgtp's Avatar
How does a Mustang dyno load up? I figured about having to tune more conservatively on a Dynojet (simply less load).
Were you saying you still had to pull back about the same amount as a dynojet?
