370ci dyno numbers?
Old Feb 13, 2007 | 09:49 AM
ATVracr's Avatar
Originally Posted by Wong
Stock bottom end?
370 cannot be stock.
364 is a stock LS2 or LQ9
.030 over is a 370
Old Feb 13, 2007 | 10:42 AM
Wong's Avatar
.030 over is a 370
I've seen people round it up on here before though so figured I'd ask.
Old Mar 2, 2007 | 10:56 AM
oldschoolmuscle's Avatar
anybody else ?
Old Mar 4, 2007 | 01:37 AM
4yall2nv's Avatar
so what the differance between the lq4 and lq9?? 6.0l? r they both 364? thanks
Old Apr 11, 2007 | 11:38 PM
i think its just the pistons one is dished and the other is a flat top.
Old Apr 12, 2007 | 07:32 AM
94snake's Avatar
Mine made 475 on a Mustang dyno ... its set up loose for the spray though.
Made over 750 on the jug
Your car is sick Nice vid in your sig as well!
Did you run the 9.51 on pump gas?
Old Apr 12, 2007 | 07:49 AM
ATVracr's Avatar
Thanks!
No, it went 9.63 on Pump gas.
Old Apr 12, 2007 | 07:57 AM
gator's 99TA's Avatar
we have a local running a 374 alum motor (square motor). "loudmouth ls1" and ran 9.40 @ 144 on the jug. no idea what it dynos. who cares.
Old Apr 12, 2007 | 07:59 AM
GrannySShifting's Avatar
Originally Posted by 10secclub
his car should be good for mid to high 10"s on motor and should see some 9"s on the bottle
That would be a sucky 550 rwhp, should be good for 10.2s on the motor and 9.2s on the bottle fo rizzal.
ATVs traps 125-126 on the motor in nitrous trim
Old Apr 18, 2007 | 04:04 PM
PunkNPonys's Avatar
Thanks!
Badass setup you have there. I am assuming your running a TH400? Can you give us more details on your setup. What size cam are you running?
Old Apr 19, 2007 | 08:17 AM
Pump gas, AFR head trim it had a cam with 242-244 dur. on the intake lobe
