Gears VS RPM Graph Argument
I would think the power graph and peak hp would stay exactly the same, but it would take just a tad longer to run thru the gears with 4.10 gears..hence they are wider a tad..
Is this correct or will powerband somehow would some how change with the same exact setup (just different gears) as my buddy claims?!
Another question is would you lose few hp with 4.10 gears over 4.30 gears on a chassis dyno?
You would lose power going from 4.10 to 4.30 but not much. Now if you went from 2.73 to 4.30, your dyno would show the difference.
