Which graph would you choose?
Old Feb 17, 2007 | 09:06 PM
25psi's Avatar
Default Which graph would you choose?
http://i140.photobucket.com/albums/r...sports/800.jpg
Built 350z with a stroker ar 20psi
http://ktgutz.home.comcast.net/ecsdyno.jpg
346 supercharged 15psi
That is a horrbile graph of a 346 IMO. Someone on another forum is stating this is a flatter graph compared to a 350z. What are you opinions
http://i140.photobucket.com/albums/r...-dyno2-633.jpg
This was at 13psi on a 350z.
Old Feb 17, 2007 | 09:52 PM
blck89rs's Avatar
theyre right it is flat but it is flat on an upward slope not flat across
Old Feb 17, 2007 | 10:19 PM
25psi's Avatar
What there saying is, the 350z graph doesnt compare.
Old Feb 17, 2007 | 10:43 PM
travie319's Avatar
wow there is a 800rwhp 350z here in SOCAL?
that should be a impressive car..........wonder if I'll ever see it in action.....
Old Feb 17, 2007 | 10:55 PM
25psi's Avatar
Yea that shop is very impressive. They make there own rods as well. Each rod, is rated at 600hp. Next week, they will see if they can hit the 1000rwhp mark.
Old Feb 17, 2007 | 11:10 PM
SSilverSSurfer's Avatar
the first one looks awesome, that would be my choice, nice and flat, thats power across the board baby
Old Feb 17, 2007 | 11:14 PM
25psi's Avatar
I honestly dont know why, they would compare the supercharged 346ci motor and say thats a nice graph.
Old Feb 18, 2007 | 12:35 AM
THE_SUPRA's Avatar
i thought that the 3.5 nissan block was a P.O.S.?
Old Feb 18, 2007 | 01:58 AM
sentry65's Avatar
that 350Z is stroked to 4.24 liters with 20 psi on a twin turbo kit, ported heads, cams, big *** exhaust, etc
that said, based on dynographs alone, I'd still take the supercharged 346 car. Better throttle response, no lag and it has better low end power as well as more top end power. I own a 460-480whp vortech supercharged Z, so it's not like I'm biased against Z's or anything. Now as far as handling goes I'd take the 350Z
here's all three of those graphs overlayed
346 is green
4.24 stroked 350Z TT is blue
regular 350Z TT is red
....yeah I'd take the 346
the normalization of the 20psi 350Z graph is a little misleading with making it look flat when really it's not so flat. Looks more like a supra curve - which would probably look flat if you only showed 6000-9000 rpms
honestly the Z is going to need nitrous early in the powerband and have it taper off with a progressive controller to have any chance of keeping the torque curve somewhat flat. I dunno, I'm just not a fan of turbo curves in general. The torque curve always ends up shooting up and dropping fast at some point in the powerband
Old Feb 18, 2007 | 02:19 AM
sentry65's Avatar
maybe a couple years ago when people spent more time blowing it up than making decent power with it. The platform has matured and better parts are available now and there's more knowledge for getting reliable power
Old Feb 18, 2007 | 07:42 PM
bboyferal's Avatar
I'll take the 350Z curve.
Old Feb 19, 2007 | 11:33 AM
Angus66's Avatar
Thumbs up
here's all three of those graphs overlayed....yeah I'd take the 346
That's a great post right there - both curves on the rpm same scale so that they can be compared objectively...
Old Feb 20, 2007 | 08:37 PM
bigman's Avatar
The VQ has the potential aftermarket to be the next 2jz
Old Feb 21, 2007 | 12:30 AM
RedBeauty84ZX's Avatar
The new VQ going in the 07+ G35 and 350Z, the VQ35HR, has quite a bit more potential then the older VQs.
Old Feb 21, 2007 | 07:24 AM
PendragonZ's Avatar
Chop-Foo Director
Have fun in the dyno section.
Old Feb 21, 2007 | 11:05 AM
BlueSix's Avatar
Looking at the two dyno's i'd take the 346 if i were looking for a daily driver type car. The graph of the Z starts at 3600 RPM. At that point in the run the car is making 300 rwtq. At 3600 rpm the 346 is making 525 rwtq. If i wanted a car to make top end runs i'd take the Z, but i like low end grunt and driveability.
Old Feb 21, 2007 | 12:57 PM
sentry65's Avatar
the thing is that the 350Z dyno isn't showing is that on that particular car since it's turboed, the rpm that you start going full throttle at is going to have an effect on the dyno curve since it takes a split second for the turbos to spool up so the graph is a little misleading in a way. It really does have a little more low end power than it looks like it shows.
That's the beauty of an NA or supercharger engine, there isn't any lag to get "full" boost that the rpm you're at is capable of delivering with a turbo.
The tuner who tuned that Z adjusts the turbo gain with higher boosted setups so the turbos spool later to help prevent overboost. If the car ran less boost, the gain would be adjusted to let the turbos spool earlier for more power down low, but obviously less up high. Generally with 16+psi on even the 4.24 liter engine, power below 3500 rpms isn't going to be anything special
That graph I posted has 3 graphs on it BTW if anyone missed it. The 346's graph is slightly faded. I should have made it stand out more...
anyway, the 4.24 stroker kit is freaking nice on the Z. It should add roughly 50-55whp pretty much across the board on an otherwise bone stock engine if it had the same compression ratio. Still not as big or as powerful as a LS1/2/6/7 engine, but with some moderate forced induction the car will be decently quick and well rounded for different types of motorsport driving
Old Feb 22, 2007 | 02:12 PM
sentry65's Avatar
That Z hit 855whp last night with 22 psi
Old Feb 22, 2007 | 03:06 PM
Wong's Avatar
Isn’t the new skyline supposed to be around the same displacement with forged bottom end and twin turbo?
Old Feb 22, 2007 | 03:20 PM
Sigforty's Avatar
I like the low end power of the 346. It makes more power and torque at 4500 rpms versus the other combo. I also noticed the scale of the graphs is different which can help some appear more flat than they really are.
