(T-Rex)cam only predictions?
Old Mar 27, 2007 | 12:54 AM
kngkahious's Avatar
Default (T-Rex)cam only predictions?
i am looking at a 98 trans am and wanted to know what kind of results i can expect out of it.with these mod's t/a cam only(t-rex), full bolt ons, th350, tci 4000 stall, 4.10s, adj. control arms, adj. panhard, spohn t/a, UMI k-member, UMI A-arms, Spohn rear drag bar, Spohn SFCs, qa1 r series, drag lites with 325/50/15 MTs
let me know what u think.what kind of power should it make.and what kind of times should i expect.
Old Mar 27, 2007 | 01:02 AM
Quik's Avatar
wrong section
Old Mar 27, 2007 | 01:22 AM
bww3588's Avatar
yes, wrong forum. although you cant blame him for overlooking, i did the same, when they changed it around, i was in here looking for cam results on an LS1 and finally figured out why no one in here had LS1's
Old Mar 27, 2007 | 09:04 AM
8ty8 LS1's Avatar
dunno about dyno numbers...but i would think 11's for sure...
Old Mar 27, 2007 | 09:30 AM
Patrick G's Avatar
LS1 Tech Administrator
Moved from LS2 internal section.
I think you'll be around 350 rwhp, but you should definitely run 11s (provided you get traction).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 27, 2007 | 11:12 AM
import slayer's Avatar
350 seems low
Old Mar 27, 2007 | 12:25 PM
Patrick G's Avatar
Originally Posted by import slayer
350 seems low
Not if you think about all the power sapping items:
'98 heads
4000 stall with unlocked TH350
4.10 gears
Big heavy tires
350 rwhp might be generous!
__________________
Old Mar 27, 2007 | 09:20 PM
98camaroLS1M6's Avatar
'98 heads
4.10 gears
Big heavy tires
Sounds right, 350 provided the tune is perfect!
Old Mar 27, 2007 | 11:03 PM
kngkahious's Avatar
so what forum do i need to put it in.also if i spray a 150 shot it would put me in the low 10's high 9's correct.
Old Mar 28, 2007 | 11:31 AM
BADSZ28's Avatar
10's, but no 9s. Not on a 150 hit. Unless the car weighs 3k with you in it.
Old Mar 29, 2007 | 12:36 AM
kngkahious's Avatar
race weight is 2950 lbs it has a 5k stall not 4k kooks headers and an ls6 intake.i think i should be in the 9's.with about 400rwhp motor and 600rwhp on the gas.the car also has a trans brake.
Old Mar 29, 2007 | 09:43 AM
BADSZ28's Avatar
As long as you can hook and the power is there, yeah, 9's are in it then.
Old Mar 29, 2007 | 09:55 AM
Bryan @ Speed Inc.'s Avatar
does anyone think he'll actually get through the traps under power with that set up???
5000 stall, 4.10 gear, 28" tire, and a 200 shot?
Old Mar 29, 2007 | 10:01 AM
BADSZ28's Avatar
If he revs it past 7k. But yeah, a 3.73 or lower would be better for the juice. Even a 4k stall. He is set-up for NA seams.
Old Mar 29, 2007 | 11:01 AM
Patrick G's Avatar
5000 stall will work great NA, but chances are good that a 150-200 shot will blow right through the converter. Need to decide where you want your best ETs to come from...nitrous or motor.
__________________
Old Mar 29, 2007 | 11:42 AM
Kraest's Avatar
Like Patrick said, if you plan on spraying it, you'll need a tighter converter than a 5000 because the extra power from the nitrous hit is going to flash the hell out of it.
Old Mar 29, 2007 | 11:44 PM
kngkahious's Avatar
i understand that. but what i want to know is what u guys think about this deal.whats going on is i am looking into buy ing this car.or tradeing for it rather. i have a 06 gsxr 1k with 3k miles this guy wants the bike i owe 11kish on the bike. he is trying to sell his car for 9500 its an odd situation do u think the car is worth what he is asking for it.heat/ac power stearing and radio have been removed.has racing seats and a roll cage in a coupe with the 7.6 rear still in the car.it seems to be in good condition.i'll post up pics when i get them probly tomorrow.just let me know what u think should be done.i dont ride the bike any more.it just sits in the garage but i dont want to make a bad decision.also what do u think the car is worth/ actually sell it for.estimates untill i get the pics of the car posted up will be fine.then u can reassure your guess.just let me know something. also u think if i put the correct stall in the car i could do a 9.80 on the juice no more the a 200 shot probly a 150.
Old Mar 30, 2007 | 12:45 AM
daniel6718's Avatar
where are you located?
Old Mar 30, 2007 | 08:15 PM
AlexLs1's Avatar
360-370ish horse to the tires??? Only reason I predict is that a guy on this board goes by the name Camaro SS (car is pewter) he had cam only in an A4 (same cam) similar mods here and there pulled around 370 to the wheels. No idea on the torque. But somewhere in that ball park, I would think?
Running bottom 11's.
Old Mar 31, 2007 | 02:11 AM
kngkahious's Avatar
temple ga
