Correction Factor
Old May 11, 2007 | 10:39 AM
zz4camaro1980's Avatar
Default Correction Factor
I found this formula online:
Cf=1.18((990/Pd)*(Tc+273/298)^.5)-.18
Pd=pressure in mb
Tc=temp in C
Is this all there is to it, does this apply to both hp and torque?
Just looking to confirm that this formula is correct.
Thanks in advance.
Old May 12, 2007 | 09:27 AM
DynoDR's Avatar
That is one correction formula that is used. That one there is J1349. Also to get Pd you take the actual air pressure and subtract Pv (vapor pressure) from that.
More correction factors..
https://ls1tech.com/forums/dynamometer-results-comparisons/680858-sae-vs-std.html
Pd=pressure in mb
Tc=temp in C
Thanks in advance.
