Vinci XXX cam
Old Jun 7, 2007 | 03:05 PM
lilbuddy1587's Avatar
Originally Posted by mhoglund
according to the tuner it was locked. Tony Mamo keeps telling me to take off the 1.8 rockers which Joe and Rodger told me to leave on.
1.8 rockers are holding you back. No matter how much those other guys are telling you to keep them on, the sooner you take them off the better. I'd take Tonys advice. Based off of what I've seen from everyone running 1.8 rockers, their #'s are less than stellar but when they switched back to stock 1.7's they picked up the "lost power"
Old Jun 7, 2007 | 04:00 PM
405HP_Z06's Avatar
I would have to agree with Vinci on the rockers. Can you email your tune? Do you have any logs to peruse?
Old Jun 7, 2007 | 07:36 PM
vettenuts's Avatar
If the rockers are causing an issue, it should show on the dyno. Do you have one to post? Also, which AFR springs are you running? I had some issues with the 1.8's that were valve spring related, but it was very evident on the dyno.
One other option if there is another around, is to put it up on another dyno for reference.
Old Jun 7, 2007 | 08:39 PM
mhoglund's Avatar
I will be meeting someone next week, and if you want I can send you my tune.
Old Jun 8, 2007 | 12:56 AM
mochiles's Avatar
Originally Posted by lilbuddy1587
These vinci cams make so much torque.....
How do you figure? Bolt-on M6 cars make that much torque (or at least mine did). Seem low for a 6 speed with all those mods.
Old Jun 8, 2007 | 10:33 AM
That was my point....
Old Jun 8, 2007 | 07:04 PM
mochiles's Avatar
Ahh.... my bad. Sarcasm is tough to detect through the internet
Old Jun 8, 2007 | 08:11 PM
MikeG's Avatar
Talk about a 'safe' tune...that air/fuel ratio is ludicrously rich.
Old Jun 9, 2007 | 11:22 AM
vettenuts's Avatar
I just looked at my cam curve, Vinci 056. I think your tune needs some work as your curve seems really low in the lower RPM's even compared to mine, and mine is 216/225 on the duration.
Old Jun 9, 2007 | 08:47 PM
MJD's Avatar
MJD
You think it will be worth my while to get in touch with my tuner about tweeking the tune a bit?
Old Jun 10, 2007 | 10:02 AM
mrr23's Avatar
yes. 11:1 is very rich. need to be in the 13:1 range.
Old Jun 10, 2007 | 10:07 AM
  #32
MikeG's Avatar
Definitely.
Old Jun 10, 2007 | 07:43 PM
  #33
vettenuts's Avatar
Based on my curve in comparison to yours, I think there is a lot left on the table. If you trust the tuner, go back. If not, find someone else.
