02 Z06 cam only results
232/234 .595/.598 112 cam
Kooks Long tubes and catted X-pipe
Bassani Catback
Underdrive pulley
Blackwing intake
the car drives just like stock and made this power in 96 degree weather. i was very impressed for a cam only car
417.7rwhp and 395.2rwtq, i wonder if i will see any more power when the motor breaks in?
Whats so bad about it?? It falls off a little early though, so if you are complaining about that I agree.
I don't really see any reason to complain about your CAM only results. That guy is crazy I think. I am sure you are feeling the difference with that new cam. Have fun.
as far as heads go im going to do it right the first time and step up to a AFR 205's and a Fast 90/90 when i get a extra 3500ish laying around
Good cam only numbers, and they are right a few more bolt-ons and you are looking at 20-60+rwhp depending on the what you get...I figure AFR 205s would be quite a bit and then some more with the FAST.
Good luck, enjoy the new power.
So I am going say that afr heads alone will 50 rwhp and 40 rwtq. You have a good cam choice. Its been proven time and time again that bigger isn't always better. You have power under the curve and thats what everyone should be after. Have fun with the car and please let me know if you decide to put some heads on that thing. 215cc Trick Flows would be a good option as well.
