408 or 402???
P.S. any help from any sponsors would be greatly appreciated. Price quotes would be even greater help. I would like to know what I would be looking at to finance the swap.
Thanks, Justin
Erik from HKE and Greg Good for the heads!
Sorry for the highjacking!
I'm also in the market for a stroker as well and I would like to know the same things as you.
Got a Century built Stage 3. Also a custom converter for spray (3200). Built with all my mods in mind! I don`t spray threw shifts!
If you have a little more money, an LS7 based 427 or 440 would be the ticket if weight savings is a goal. If you don't mind an iron block, a 454 LSx-based block would be cheaper than the LS7-based engines and would give you a really big engine with a huge power potential.
To give you an idea of the price differences, I configured some shortblocks with Diamond Pistons/Callies Crank/Compstar Rods and ARP hardware (and LS2 conversion components where applicable):
402 - $4900
408 - $4305
418 - $5295
427 - $6605
440 - $6639
454 - $6335
As for heads, the L92/L76 combo would be a really good budget option or the LS7 heads and intake (on the 427+ cid) would be cheaper than aftermarket stuff and make huge power.
Here is a 347 option for you as well.
http://www.motorsporttech.com/c5_engine02.asp
A 383 is a perfectly viable option for you though, you could reuse your heads, just a cam swap and still make soem good power, save you the cost of a new block as well, so it might be something to consider
there will be no power diffrence only wieght and cost. so chose on that. if its not a track car just go iron.
or maybe try a search there are tons of 402 408 threads to look at and help you decide. good luck you will love the added TQ no matter what you choose
