Take guess at how much power i will make!
Originally Posted by 1lejohn
I'm thinking 400+. My car is very close to your set up ,it run's 11'0s @ 122 in the Texas heat. My cars dyno#s are in my sig. I've since upgraded to 4.11 gears and a fast 90 intake and T.body. The gears will cost you some HP. You should have a good running combo.
Well I finally got it tuned. My car dyno'ed 408hp/370lb-ft's. Would have been more but the 3800 stall, built tranny, and 4.10's are robbing some power but i am very happy with the results. Alvin from pcm4less.com did the tuning. I will post a graph and video soon as Alvin uploads it for me.
Here is the ink to the graph. I am second on the list.
http://www.carolinarides.com/forum/s...ad.php?t=27555
Good to see you did more than I thought. Awesome job
Car should be a ripper. High 11's all day @ 114-115.
Here is the Video of my Dyno run with Alvin from pcm4less.com behind the wheel.
http://www.youtube.com/myglk40
Here is the latest numbers, I am now up to 428hp/390ft-lbs. I was able to achieve it with cooler air temps, power bond underdrive pulley, and a little porting work. Tell me what you think.
