TFS 235cc vs Stage 3 LS6 on stroker
It is interesting how the higher compression Stage 3 LS6 heads start to catch up to the lower compression TFS235 head at 6400rpm or so. They probably were so hogged out, that the poor flow velocity was killing your low/mid/fairly high end torque, until WAY up near the peak power rpm, where the flow velocity is less important.
This is where an ENGINEERED head like the TFS has enormous advantage over ported GM heads. Power throughout the band, due to high velocity AND flow.
Thanks for all the cool info, and congrats on your great setup.
are you going to be heading to the track anytime? Id love to see what that beast runs.
Congrats on the results, and I know you must be happy to be able to put pump gas in your car and drive it anytime you want without detonation.
