Need Parts
Old Aug 29, 2007 | 02:48 PM
misho911's Avatar
Question Need Parts
Hello Guys,
I have Trans Am 1999 M6 LS1 5.7L and I got 426 rwhp and 396 torque
the Parts:
Pacesetter LT and custome exhuast dual to the end with true x-pipe and tow Maganflow mufflers
Cylinder heads Partiot Stage 3 225cc and 64cc champers
Camshaft Xtreme Energy 238/240, .605/.609, 112LSA
Volant Ait Intake filter System twin filter
ASP Pully, BBK throttle body 80mm and Intake Manifold LS6
Injectors 30 lp, Fuel Pump 255 lp, MSD Plug Wires and NGK 55
Ring and Pinion 3.73
S.P.E.C Stage 4 with aluminum flywheel
I got 11.609@193
http://www.youtube.com/watch?v=8C-POYhpD84
So i would like to change the parts with another parts what is more powerful and better acceleration, so could someone help me about what are the parts without use forced Induction and Nitros to get around 460 to 520 rwhp and torque??????
Thanks
Old Aug 30, 2007 | 11:53 AM
capn smokey's Avatar
520whp isnt really feasible in a stock cube pump gas 347 but if you ditch the patriot heads, step up to some afrs or something like that, bump the compression to 11:1 or so, go with a little nastier cam(244 at least), get a fast 90/90, get a ewp, and through a cutout w/ a good tune you should hit 460-480. Or the easy way out is a 100 shot, it wont hurt anything just do it.
Old Aug 30, 2007 | 12:14 PM
misho911's Avatar
thanks for your help, about the camshaft what is the no's or from where i can buy it?
