my 383...????
my set up is as follows:383 c.i. LS1 block, 3.905 bore/ 4.00 stroke
eagle crank, compstar 6.125 rods, diamond pistons with -2cc relief
fully balanced internals
AFR 205 heads, 11.2:1 CR, .660 lift springs
LS6 intake, ported Tb, 36lb injectors, UD pulley
PAtrick G spec cam...238/240 .605/.612 112lsa
jet hot lts, ory, magnaflow catback
7.400 prs, comp lifters, no egr, or air pump, no cats, tuned by FBody Central
what does something like this put down??? any guesses
I did a 382 for a member here with TFS heads, 238/240 cam, FAST 90 setup, and all bolt ons. It made 455rwhp and 470rwtq with less compression (static and dynamic) than yours.
4.10 Will eat some power (not alot)
Mustang Dyno.
Maganflow is a good flowing Exahust but I think you need Cutout.
Buy Fast intake and TB and Port them you will gain 20-30rwhp.
The numbers I posted is Close to 460rwhp+ and 450rwtq+ ON DYNOJET Thats not bad at all If this was my car I'd be happy but 1st thing I do is throw Cutout the fast setup will cost alot but Cutout are cheap and worth it
NOW PLZ TELL ME US THE NUMBERS ASAP OR
J/K.
or if you have an account in www.Photobucket.com
Well your numbers are not the greatest but not that bad IMO.
Thats close to 450rwhp and 440rwtq on Dynojet I think the Exahust setup is holding you back.
My friend Dynoed his cam only T/a made 330rwhp with crappy Flowmaster he opened his cutout and made 389rwhp
Maganflow is great exahust but not for big CI Motors.
And Fast setup will help the motor to breath alot better.
Good luck man.
to anyone out there... looking for a fast 90/90 set up, a decent rear and a cut out...
