*Help* Underpowered Torquer V.2 on 02 M6 LS1
Old Nov 13, 2007 | 04:06 PM
  #41
bad6as's Avatar
sorry i went 12.4
Old Nov 13, 2007 | 04:42 PM
  #42
PewterScreaminMach's Avatar
Originally Posted by bad6as
he has a 232/234 cam and traps 113
thats not right he should have another 3-5mph
1) You didn't answer my questions.
2) He shouldn't have another 3-5mph, he should have more power, which results in higher mph. For his "POWER LEVEL", he is running good times and trapping well.
Old Nov 13, 2007 | 04:43 PM
  #43
Cool, no problem.
I'm not trying to be a jerk, just trying to make a point .
Old Nov 13, 2007 | 05:23 PM
  #44
slow trap's Avatar
well to the OP= if the car put down 320 rw with lid & catback only with those heads then they were performing up to par . rwtq looks inline as mentioned so i would look into a couple things =
what octane gas are you running ?
the tuner may have got knock and not put in enough timing in the upper rpms,i would think around 28* or so at peak hp should be where it needs to be.you could of had less than stellar gas in the tank when dynoed also.
