Please Help With Dyno Graph
Old Nov 25, 2007 | 06:28 PM
408lq9's Avatar
Default Please Help With Dyno Graph
this is 1 of three dyno pulls, we made 730rwhp on the 3rd pull. we had a lot of will spend on each pull. trying to see if this is wheel spin or converter slipping. 408 nitrous motor. 100 dry 150 wet plate.
Old Nov 25, 2007 | 10:16 PM
ms4z28's Avatar
it could be wheel spin try it again in fouth gear
Old Nov 25, 2007 | 10:42 PM
beardWS6's Avatar
Whats your build look like. I have a 408 set-up for spray. I run a 200 shot. As for the sheet, might be wheels spin!! With spray the TRQ hit is awsome.
Old Nov 26, 2007 | 05:40 AM
Slowhawk's Avatar
LS1Tech Sponsor
Instead of rpm to the graph against mph.
Old Nov 26, 2007 | 09:52 AM
mrr23's Avatar
what are the rpm points the stages activate? to me, it looks more like the first kit comes on, then the second.
here's what wheel spin looks like on my 408 with a single 250 shot.
here's the same run using mph, so you can get a little better view of the run
Old Nov 26, 2007 | 11:08 AM
408lq9's Avatar
it's has a 400 trans with a dana rear with 3.73 gear. 4000 converter. motor alone made 496rwhp, but it drop to 455 since we pulled alot of timing out.
Old Nov 26, 2007 | 11:09 AM
edcmat-l1's Avatar
That^^ is what I'm used to seeing from wheel spin. The top graph, how it loops back. Post #5.
