hit up dyno again surprising numbers...
Old Jan 5, 2008 | 06:48 PM
XX11SECZXX's Avatar
Default hit up dyno again surprising numbers...
went on the dyno agian. put down 333rwhp and 360rwtq on motor. and the bottle passes... well first pass converter locked for some odd reason their dyno wouldnt graph it but it showed a reading of 475rwhp and no torque reading, he said it was due to my msd box backfeading through his computer when it pulled timing out. third pull didnt graph either but showed 467rwhp and the lock up only stayed locked through half the run. 4th pull they removed the wire for the tach and ran the dyno based off of mph and my converter wouldnt lock up it put down 458rwhp and no torque read because there was no rpm to go by. the lock up quite working because im an idiot and havent put the right wire connector in so it pulls out sometimes, when i got home i put it on the lift hooked the wire back up and its working fine. from what the told me i should have made around 500 to the wheels if my converter was locked and my msd wasnt screwing it up. o yea and i looked at my plug wires and one was resting on the header.
Old Jan 7, 2008 | 03:14 PM
DANOZ28's Avatar
is this an LT1 (383) or an LS1? what yr car, thx!
Old Jan 8, 2008 | 08:24 AM
XX11SECZXX's Avatar
its an 86. carbed.
