Longtube swap only dyno request...
Old Jan 22, 2008 | 07:51 PM
5.0stang's Avatar
Default Longtube swap only dyno request...
How much power have you guys got just by swapping out longtubes and swapping out for a matching mid-pipe?
What is so restrictive on the stock manifolds? What are the sizes of your longtubes?
Old Jan 22, 2008 | 08:52 PM
bigpapi211's Avatar
look for up to 350rwhp. i got a pair of hooker super comps. the lt's allow for more scavenging of exhaust gasses
Old Jan 22, 2008 | 10:08 PM
Frost's Avatar
depends on where you begin, but 335-345 seems about the norm
Old Jan 23, 2008 | 12:31 AM
98camaroLS1M6's Avatar
you should pick up 15-20rwhp from your baseline
Old Jan 23, 2008 | 05:33 AM
s346k's Avatar
on a stock engine (lid only) i picked up 7 mph before tuning and 9 after tuning. a total of 10 mph from pacesetter 1 3/4" coated longtubes. i also added a 4k stall when adding headers, so i'm only guessing that it would've picked up more on the stock converter. this is with the stock tune, as well.
Old Jan 23, 2008 | 07:57 AM
Frost's Avatar
10 MPH from headers lid and tune? According to your sig, that means you only trapped 99-100 MPH stock, which would be the lowest 1/4mile trap I have ever seen for an f-body without some type of problem.
Old Jan 23, 2008 | 09:10 AM
PewterScreaminMach's Avatar
Originally Posted by Frost
10 MPH from headers lid and tune? According to your sig, that means you only trapped 99-100 MPH stock, which would be the lowest 1/4mile trap I have ever seen for an LS1 f-body without some type of problem.
Corrected.
OP, 10-20rwhp is a good estimate. There are a lot of variable and it sounds like you mean with NO other bolt-ons (ie pulley, ported TB, catback, etc, etc).
Old Jan 23, 2008 | 08:16 PM
formulaon18s's Avatar
Before my Super Comps and TSP TD my car was like whahhh, now after adding the parts it goes Whahhh louder and quicker. Thats the only difference I've noticed, tracks closed.
Old Jan 24, 2008 | 07:14 AM
s346k's Avatar
yes, the car trapped 100-101 bone stock. fastest trap was 111, but it averages 109-110 before the clutch packs started getting upset. had no problems in stock trim, i think the 273 gears had something to do with it. not to mention the 3,700lb raceweight when stock.
Old Jan 27, 2008 | 01:40 PM
WS6RED2002TA's Avatar
My sig has a link to dyno graph of before and after header swap.
Old Jan 27, 2008 | 11:07 PM
SladeX's Avatar
longtubes + true duals boosted me from 306HP to 349HP... so longtubes are worth it. A 01-02 may gain less (only because it starts with more thanks to the freer flowing cast manifolds).
