Dyno Results - Help!
Old Feb 25, 2008 | 12:20 PM
junkz28's Avatar
Default Dyno Results - Help!
ok, so a little backround on my car:
2000 z28 - headers, y-pipe, cut-out, 4000 fuddle converter, 4.10 gears, ls6 intake, custom cam - .573 lift 228 duration 112 lsa, 42 lb green top svo injectors, 125 shot dry.
Here's my graph. The converter was not locked, so i understand why the numbers may be a bit low. What do you guys think?
Also, maybe this belongs in the nitrous section, but what would cause the MAF to not read the nitrous going through it? Basically, the computer is not telling the injectors to add fuel so it leans out. We tried turning the nozzle backwards, it helped a little bit and yielded the same power, but it's still leaning out bad.
File Type: pdf
Old Feb 25, 2008 | 12:26 PM
1989GTA's Avatar
Was the cam degreed when it was installed? It looks like you are running out of air right away. Unless there is a problem with the exhaust.
Old Feb 25, 2008 | 12:44 PM
BlackScreaminMachine's Avatar
Internet Mechanic
mmhm, A locked converted #1 would be a HUGE benefit.
Also, if you havent already, take it to a guy who knows how to tune and understand n2o kits, Assuming you have a dry kit.
Old Feb 25, 2008 | 02:20 PM
junkz28's Avatar
the cam was aligned dot to dot it had 4 degrees ground into it.
hopefully that makes sense.
Old Feb 26, 2008 | 10:35 AM
White_Hawk's Avatar
You might be blasting through that converter. Was it specced for nitrous?
-Geoff
Old Feb 27, 2008 | 03:17 PM
junkz28's Avatar
no, the converter wasn't specced for nitrous. how does that have to do with my motor leaning out though?
