Originally Posted by -Joseph-
(Post 11572708)
If Darton sleeves the block, all LS2/LS7 Gen IV blocks end up really close to being the same thing as the final usable product. Gen IV blocks can be wet or dry sleeved with good results, with dry sleeves being a tad more economical than the MID darton sleeves. The Darton dry sleeves are stronger than the factory LS7 sleeves which are prone to cracking if not careful. The MID sleeves are the strongest option for sleeved aluminum blocks. Talk to Steve at Race Engine Development for the best sleeve work. will that MID resleeved LS1 block be able to handle forced induction without failure or leaking coolant? thanks. |
Originally Posted by David Gordon
(Post 11573356)
Joseph you didnt answer my question? How much power in a small street cam? Friend of mine got the setup above WITH Stock Catback, stock Intake and stock TB the car drive really close to stock and pulls hard Made 560rwhp 505rwtq you can go with this setup with ported Intake and tb or the new FAST 102mm I;m sure 580rwhp shouldnt be a problem. |
Originally Posted by Jon@Texas-Speed
(Post 8875883)
We just finished installing a ported ls7 intake on our shop z06 & she's really starting to show her potential! Car made just under 600rwhp before the ported intake & throttle body! Here's the mods: PRC CNC Ported LS7 Heads TSP Ported TB & LS7 Intake Kooks 1 7/8" Headers TSP LS7 Camshaft Killer Bee Intake TSP Dyno Tuning!! http://precisionracecomponents.com/tspz06.jpg |
Originally Posted by Abdullah
(Post 11575875)
btw, if i use a MID resleeved LS1 block will it be as strong as LS2/LS3/LS7 blocks? will that MID resleeved LS1 block be able to handle forced induction without failure or leaking coolant? thanks. |
Originally Posted by Haans249
(Post 11581523)
Awesome power!!! What injectors are you using? What injector duty cycle did you see? |
Joseph, I was told once you port the stock throttlebody and intake the car is never the same. It causes surging and iratic idle. Is this true? |
(Post 11583523)
Originally Posted by Stang's Bane
(Post 11583560)
I can answer this. That is absolutely not true. |
Originally Posted by Jason 98 TA
(Post 11548188)
Guys we're going to start working on the 454 lsx short-block to replace this one! I'll keep ya posted!! |
Originally Posted by JakeFusion™
(Post 11603005)
4.250" Stroke? |
(Post 11603814)
i think it will be 4.185" bore X 4.125" stroke which will yield 454ci. Sorry, I had quoted the wrong thing earlier. This is what I meant to ask 4.250" stroke for:
(Post 11559646)
We're working on a LS7 block 454 for it :) Gonna stay aluminum for the Z :) |
Very nice results. |
bump we're currently running LS7s on the cnc machine in case anyone needs a set! :) :) |
(Post 11911344)
bump we're currently running LS7s on the cnc machine in case anyone needs a set! :) :) Just bought one for a friend. :D I'll post some numbers very soon. :chug: |
i wish we could see a ported lsxr intake/tb combo on this |
so do you think strokin the ls7 to a 440 would help with drivablility issues with this cam? also, what results do you think you could see with the new fast combo and the 440 with this cam? on a side note, do you think you spray a 100 shot on top of this setup but with a 440? just getting some ideas... |
Aren't horse power and torque supposed to cross at 5252. If not then its not an accurate horsepower number. (Torque x Engine speed) / 5,252 = Horsepower |
Originally Posted by gogto
(Post 12049019)
can you you put some input in from my post please:drive: |
track times???? |
© 2024 MH Sub I, LLC dba Internet Brands
