2006 Corvette LS2 Dyno #
Old Mar 10, 2008 | 05:58 PM
cowboyup's Avatar
Default 2006 Corvette LS2 Dyno #
Does anyone know what a BONE stock C6 M6 dynos at?
My buddy has 01 Z06 with Borla, X-pipe, CAI..
He wants to run em.. What will the outcome be?
Old Mar 10, 2008 | 06:28 PM
Evilways's Avatar
Stock C6 LS2s dyno about 345-360 rwhp for manuals and 335-350 for A6s (the spread is due to dyno inconsistancies). They're also less than 3300lbs . Gonna be a close race. Driver will be the deciding factor in this one.
Old Mar 10, 2008 | 06:33 PM
cowboyup's Avatar
WOW.. 345-360.. thats a big window..are these LS2's that inconsistant?
Old Mar 10, 2008 | 06:41 PM
cowboyup's Avatar
Sorry.. I just re-read your post. Spread is due to dyno inconistancy
Old Mar 10, 2008 | 07:16 PM
venom ws7's Avatar
Driver race for sure both have similer power but I think Zo6 weigh a little less.
Old Mar 10, 2008 | 09:24 PM
Chris81's Avatar
It seems that the Z06's usually have a slight edge stock for stock due to the lack of torque management.. the C6's are definitely capped up from the factory a little more..
Old Mar 12, 2008 | 01:49 PM
user 70810891082's Avatar
The key there is BONE STOCK. C6s have a very intrusive torque management system which slows the car down at the track and gives varying dyno numbers.
Pre-tune, the 01 Z06 wins... post-tune, it's a tie... maybe an edge to the C6.
Old Mar 12, 2008 | 02:08 PM
PewterScreaminMach's Avatar
I give the edge to the Z06 (depending on year), lighter and similar power typically, also based on track passes I've seen. With the mods your friend has, I'd say lights out to the bone stock C6 LS2 unless the guy outdrives the Z06 (obviously), or if you're mistaken and he actually has an LS3.
Old May 13, 2008 | 03:03 PM
cowboyup's Avatar
Well.. Finally raced him..
Went from 30 roll.. even until around 80.. pulled him a car at 110...
Good race.. I dynoed at 372..at MTI..NOW he is getting H/C/I. DAMN..LOL
Old May 13, 2008 | 03:12 PM
Just like I thought.
He'll rape that car once he ditches that weak stock cam.
Old May 13, 2008 | 03:14 PM
khaos288's Avatar
just get headers, a realllly good tune and a cam....then you win still :-)
Old May 13, 2008 | 03:15 PM
Doh, I'm confused. Do you have the C5 or C6?
Old May 14, 2008 | 01:14 PM
fueledpassion's Avatar
If the Z06 get's a H/C/I swap there is no way that C6 will touch him without the equivalent mods. Those LS6's are beastly w/ H/C setups. However, if the LS2 has H/C/I then it will definately be a much more competitive race.
I think those Z06's have 3.73's? That makes a huge difference with the higher HP setups. If the Z driver learns to hook good then it's a no contest. I seen stock C5 Z's go high 11's quite often w/ DR's.
Old May 14, 2008 | 03:03 PM
cowboyup's Avatar
I have a C6.
MODS:
MTI CAI
J. Cohen Tuning
Ported Throttle Body
Ported LS2 Manifold
Dynoed at 382rwhp..
Not bad for everything else stock... Runs pretty strong..
Old May 14, 2008 | 05:26 PM
pdd's Avatar
pdd
nice race
