408 w/ 241's 408 w/ home ported 241's, home ported FAST 90, 244/250 @ .050, 621/615 lift, 110 lsa, Patrick G spec cam, Pacesetter long tubes, true dual, x pipe, dumped before axle, M6, Moser 9", 4.11 gears, At the dyno now for dyno tune by Pro Dyno Tech on a Dyno Mite dyno. Put your prediction in now. Should have numbers tomorrow. |
Was there today. GORGEOUS car! |
430/410 |
465-470 Hp 440-450 Tq |
455/445...could be more depends on how well those 241s are ported. |
490/500hp / 460/470tq +1 ... A lot will depend on those heads! |
540/530+ ? :-) |
470/455 |
Originally Posted by WhiteS13
(Post 9094797)
540/530+ ? :-) |
I have not picked the car up yet. Did have a brief conversation with someone there today and was given ball park numbers. I will post dyno sheets when I get them. I will say the numbers basically floored me so I want to see them first for myself. |
I watched the car on the dyno as well. You have a very strong running car. You did a nice job putting the car together. I can't wait to see what it does at the track. Chris |
Originally Posted by shift123
(Post 9094965)
Somebody knows somebody?:D |
What are the numbers???? Graph??? |
I am curious to know your numbers as well. What pistons did you use? I wonder if your Pacesetter's are that much better than my FLP pieces of crap? |
:corn: |
so what were the numbers? |
From one of the above posts, it seems the numbers are 540/530 |
Very interested on what it put down :D |
(Post 9098658)
Lets just say I love your car. haha. I have two pictures I can post if you'd like. Thanks I will be picking up the car and the dyno graph this evening. I will have them posted late this evening. Probably around 10pm or so. I was told on the phone something like 540/530. I was pretty much speechless. I was maybe expecting in the 475 area being optimistic. I understand a dyno is just a tuning tool and probably not the most accurate method to rate any particular engine build. The true test will be when I get it to the track. If i come across a dyno day anytime soon w/ a mustang or a dynojet dyno where I can get a quick and cheap pull I will just to compare numbers. |
Originally Posted by Randy_S
(Post 9098761)
| All times are GMT -5. The time now is 04:56 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
