Latest ASA results
Old Apr 16, 2008 | 01:44 PM
SSsuperdave's Avatar
Default Latest ASA results
When last I checked in, my set-up was same as in sig. Since then, I've added AFR 205's milled to 62cc with .40 cometics, 1.8 crane quick lifts, 42lb/hr injectors, racetronics fuel pump. Numbers were 380/360 and I was running out of fuel above 5500rpm. Today I got my car back from the tuner and the new numbers are 409/394. I was hoping for more from the AFR's and added lift but never the less that's what I ended up with. I'll post a graph soon.
Old Apr 16, 2008 | 05:29 PM
Damian's Avatar
LSX Mechanic
Who did your tuning? Those #'s do sound low. I've seen ASA cams make 380-390 rwhp on stock heads & 1.7 rockers. Also, was piston/valve clearance checked?
Old Apr 17, 2008 | 07:38 AM
I don't remember the PTV measurements. but it was enough. As far as the tuning, a local tuner did it. I was just hoping with more fuel, lift, and air, that the numbers would be a little higher. Does anyone know what the problem could be, if any?
Old Apr 18, 2008 | 03:26 AM
bad95killer's Avatar
Post the Graph to see whats going on before we throw Any speculations !!
peace
Old Apr 18, 2008 | 05:19 AM
s10-den's Avatar
good numbers, BUT thats low for what you have.
Old Apr 27, 2008 | 02:06 AM
JBIRD02's Avatar
Yeah, I have the asa cam and I was considering the crane 1.8's. I already have a set of gmpp ls6 heads waiting to be installed, and thought the extra lift would be a good thing. I would've loved to see a before/after of the heads /cam then heads/cam + rockers!
