99 Trans Am M6 w/Bolt-ons
Old May 14, 2008 | 08:34 PM
Ogriff's Avatar
Default 99 Trans Am M6 w/Bolt-ons
My 99 T/A 6 speed. Ls6 Intake, SLP Long Tube Headers, No Cats, SLP Loudmouth Exhaust, and SLP Ram Air.
325.6 RW Max Torque
314.1 RW Max HP
Sound about right?
Was on a Superflow...
Old May 14, 2008 | 09:02 PM
Chris Gage's Avatar
Do you have a graph, seems a touch low to me but nothing to really get discouraged about.
Old May 14, 2008 | 11:20 PM
Ogriff's Avatar
Default Graph
I'll post the graph later. I dont have a scanner. Soon though.
Is the 305 stock HP advertised, mean at the crank?
Old May 14, 2008 | 11:43 PM
calz28's Avatar
i think it's a little low, the 305hp is to the wheels i suppose
Old May 14, 2008 | 11:44 PM
hellrazor's Avatar
With the intake and headers I would say your a bit low. But they are just #. Did you do all the mods at once? If the car feels stronger than before and your happy with how is runs, I wouldnt worry about it.
Old May 14, 2008 | 11:55 PM
'Trust''s Avatar
305 is flywheel GM rated power, all LS1's basically make 350HP, everything else is for marketing or to make some models seem inferior to help justify higher price tags on the more 'superior' models. I.e. F-body vs. Corvette.
For a Dynojet your numbers are a little low, and the TQ is usually 5-20 units above the HP, which is weird yours isn't. Do you have a graph? I don't know much about Superflow Dyno's so its probably dead on. If they can make any kind of simulated load on the dyno that lowers dyno numbers.
Old May 15, 2008 | 12:25 AM
peterlawl84's Avatar
I have an A4 99 t/a with kooks LT, LS6 intake, cats and borla, and the suncoast ramair box/hood and made 336.1 hp on a dyno...so I would think your numbers are alittle low since its an M6
Old May 20, 2008 | 02:43 AM
sslateron's Avatar
Yeah sounds low, and needs a tune. No cats are overrated, I think.
Old May 20, 2008 | 05:05 AM
95 Z28's Avatar
Definitely a little on the low side. Either throw it on a different dyno and see if you get similar results or take it to the strip and see if it's doing what it should. Low dyno numbers aren't anything to be bummed about if the car performs around where it should for the mods it has.
Old May 20, 2008 | 06:12 AM
Bad Blue WS6's Avatar
do you have 853's on there by chance? Just curious as to what you would do with 241's vs the 853's
Old May 20, 2008 | 11:08 AM
PewterScreaminMach's Avatar
Seems a tad low to me, but I, too, know nothing about the Superflow dyno.
Old May 23, 2008 | 05:02 AM
oberth1's Avatar
waaayyyy too low. My a4 98 with LS6 intake, Kooks, borla catback, slp intake kit made 335/355 on stock trans and rear. with 133k miles on it. Take a peek at your setup and AF ratio. something sounds off
Old May 23, 2008 | 05:14 AM
Platinum WS6's Avatar
yea man, it is low for sure, you should be in the 330+ rwhp range with those mods.
Old May 23, 2008 | 08:13 PM
smg267's Avatar
did they tune the car? Mine made 315 h.p. and 355 t.q. before the tune then 335 360 after. The only mods at the time were slp long tubes no cats through the stock catback and a lid.
Old May 24, 2008 | 10:24 AM
MattZ28's Avatar
My 02 ss with lid and no muffler made 326 330tq
Old May 24, 2008 | 11:27 AM
5_02ls1's Avatar
Default nothing
there isnt enoughj difference in any of the heads to matter....my 98 had the 806 castings and made 34x bolt ons and 38x with a smallish cam....through an a4...either he was on a low reading dyno or the car needs a tune...
