Low Dyno #'s, 408 l92's pat G cam
OK, now I see the recommendation. From July 2007. As you can see from the explanation and the dyno sheet, this is a nitrous-biased cam (200-300 shot). The curve of the 100 shot dyno show that your valve events are consistent with what will pull into the 7200 rpm range, but the pull is not as clean NA. This leads me to believe you're getting an intake restriction. Could be the intake elbow. Not many people have performed well with them on single planes unless they're running forced induction or nitrous. It would be interesting to see how you'd run with an Accufab top-mount throttle body.
LS1 Tech Administrator
It won't hurt power so much, but it will bias the engine further to making peak power at a higher rpm.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
There have been a few road blocks. After the dyno session the cam has been straightened out, he has a different added a 4150 style TB, fixed some electrical issues and fixed some of the problems with the tuning (or tuner). Transmission have been the real issue from getting to the track, but that is also coming together. New stall will be in Tuesday, and might have some motor track times next weekend if the weather is good and maybe some 150 shot runs also if everything looks to be in order.
If nothing bad happens there then some 300 shot runs will soon follow.
Jon
#32
The only real dyno numbers he has are above. After the TB swap it went back to C.A.M. and it was running rich, Jeff proceeded to lean it out and it was all down hill from there. All it would ever do was just surge on the dyno. He loaded about 3 different tunes with no noticeable difference. The the tranny started acting up (probably from the excessive heat off of the super lean engine) and puked fluid out the overflow. That was it for that day.
After getting HPtuners and comparing some VE tables from similar engines and some timing adjustments it cranks and runs better than ever. Once the transmission is back in we will get some more logs and better the tune. Then we will get some track times.
#35
The converter will be in Monday and I have the trans waiting to go in it. Joncr96z and I have been playing with my 07 silverado to pass the time.
Here is a little Vid.
http://www.youtube.com/watch?v=fMxEs3LeFgU
#40
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Good luck and get this thing back together to see what she can do w/ that 300 shot
