Gettin the LS1 S10 dyno'd!! Numbers?
Old Jun 30, 2008 | 11:34 AM
andrew69_04's Avatar
Default Gettin the LS1 S10 dyno'd!! Numbers?
getting my dynotune...what kind of numbers??
Having my truck tuned and dyno'd in the next few days. Will be ran on a dynojet in wichita, ks.
Its a 2003 S10 Xtreme LS1 T56 setup
specs on the truck are..
2000 LS1 long block
home ported 853's decked .010
comp 228/232 .588/.578 112LSA
AFR dual valve springs, titanium retainers, comp hardened PR's
ls7 lifters
ls2 timing set with TSP ported oil pump
25% UD pulley
BBK SSI intake with stock LS1 T/B
sanderson shorties
2.5" duals with magnaflow mufflers
2002 t56 6 speed
Fidanza Aluminum Flywheel and ls6 clutch
running it through a 8.5 with the stock posi and 3.08's, and 93 octane pump gas
What can i expect at the rear wheels?
Old Jun 30, 2008 | 01:14 PM
Kingc8r's Avatar
pics of said truck? please....
Old Jun 30, 2008 | 01:29 PM
Chris Gage's Avatar
Head Gaskets? Injectors? Ima gonna say 410-420 to the tires
Old Jun 30, 2008 | 01:45 PM
the injectors are whatever was stock on a 02 Trans am. I used GM headgaskets.
Old Jun 30, 2008 | 02:12 PM
Chris Gage's Avatar
The injectors are 28.8# and I believe the gasket is a .054 thickness. You may want to watch the duty cycle on the injectors, you may be ok with those ones or you may have to bump up to a 30#. When is it going to be together to dyno?
Old Jun 30, 2008 | 02:46 PM
The trucks been together for a few months. just working out all the little issues i had with it. put about 3k miles on it since i put it in the truck. has been running untuned getting 16-20 mpg. talked to my dynoguy/tuner today. he said it will be done by wed. i will try to get some video if i get to stay and watch him tune.
Old Jul 1, 2008 | 07:57 PM
Change of plans. Its getting dynotuned by Dan at Dynosport in Lincoln, NE friday afternoon. hopefully pics and video with some good numbers!!
