How does a stall affect dyno numbers?
Old Oct 1, 2008 | 08:42 PM
MYSTIC-1SC's Avatar
Default How does a stall affect dyno numbers?
Just curious how much this would affect numbers on a dyno, an example of stall would be something like a 3600 stall or 4000 stall. How would the numbers compare to a stock stall on the dyno? Just curious.
Old Oct 1, 2008 | 08:50 PM
jetlag's Avatar
Yes, you'll dyno less with an aftermarket stall...
Old Oct 1, 2008 | 09:07 PM
SlayerMaro's Avatar
It will dyno lower than a stock stall, and if you dyno unlocked, the number will pretty much mean nothing.
Old Oct 1, 2008 | 09:08 PM
LS1_K1DD's Avatar
^It would be nice telling people lower numbers and running faster times though! Haha
Old Oct 1, 2008 | 09:18 PM
MYSTIC-1SC's Avatar
thanks for the help guys, just making sure.
Old Oct 1, 2008 | 09:34 PM
jetlag's Avatar
No problem...
That's a good reason why dyno numbers with auto cars are pretty much useless.
Old Oct 1, 2008 | 09:36 PM
LS1_K1DD's Avatar
^Exactly, im just contemplating L/Ts + True Duals or Stall first.
Old Oct 1, 2008 | 09:39 PM
jetlag's Avatar
I always do exhaust first so the car will sound good..haha...but the stall was a great mod! My car came stock with 2.73s, so I upgraded first to 3.73s. Since your car has 3.23s I wouldn't worry about it yet.
Yank is offering free shipping on their converters this month
 Michael S. Palmer
Old Oct 1, 2008 | 09:41 PM
LS1_K1DD's Avatar
^Yeah i seen that. I think im sticking with an Edge. Save some cash and they have a damn good converter/customer service. Either a 3400 or 3600 with a 2.45str Andre will be building me. I definatly want speed over sound right now so im looking at the stall first.
Old Oct 1, 2008 | 09:42 PM
edcmat-l1's Avatar
If your tuner, dyno operator locks it, the stall speed means absolutely nothing, because it's taken out of the equation.
Old Oct 6, 2008 | 07:01 PM
Muerte_X's Avatar
Originally Posted by jetlag
No problem...
I wouldn't say it's useless. That's how it puts the power down when you're driving it. No one locks their converter at the drag strip (well some do at the end of the track in the last gear to get more mph). I'd rather see how it's putting down the hp differently due to the converter.
When I went from a lid only, to adding a cutout and a 3800 converter, the car dyno'd 6hp more. That was peak hp though, under the curve in some places it was as much as 40hp more! So you can see how much it helps when unlocked. If it was locked on the dyno, you'd never see the difference it makes. At the track I gained an average of .7-.9 tenths, 6hp isn't going to give you almost a full second, lol.
Old Oct 7, 2008 | 12:06 AM
bigpapi211's Avatar
do a search i made a post exactly for this reason awhile back. i lost 3rwhp with a yankss3600 from locked to unlocked.. there pretty efficient.
Old Oct 7, 2008 | 07:15 AM
forcd ind's Avatar
i had a b/b car dynoed once, we set up the engine rpms from my tach to the rollers-at 6k engine rpms, the dyno was showing a little over 5k, a lot of converter slip, didnt even make 500 rwhp
took it to the track, ripped off a 9.67, but the mph was down, i knew the converter was to loose to begin with
had we hooked the dyno tach to the engine, it would have just showed low hp #s-going off the rear wheels, i was able to see a problem, but the problem was not as bad in rear world driving as the dyno showed
when you mention chassis dyno to a converter co., you here a little silence, lol
Old Oct 7, 2008 | 08:23 AM
HaulinHawk's Avatar
Yanked here too!!!Yank dumdumdum!!!
Old Oct 7, 2008 | 06:42 PM
Johns00Z28's Avatar
I'm just curious as to why they don't dyno higher than the stock converter. If it weighs less and all it would seem like it should make more power.
Old Oct 7, 2008 | 06:50 PM
Muerte_X's Avatar
I think it's because they slip, it's like if you were to dyno with a slipping clutch, it won't be as much as if it weren't slipping. I'm sure if you were to dyno locked stock converter vs a locked aftermarket one, it would dyno higher.
Old Nov 7, 2008 | 03:45 AM
dmoss69's Avatar
Default huh?
You can't be serious?
Old Nov 7, 2008 | 05:50 AM
mikey's Avatar
LS1TECH Sponsor
If both a stocker and an aftermarket converter are locked, the aftermarket converter will show a little bit higher number. It has less rotating mass than the stock converter. Like Ed said, stall speed means nothing when locked.
Old Nov 8, 2008 | 12:14 AM
Muerte_X's Avatar
Have you ever held an aftermarket converter? My 245mm full of fluid, still weighs less than the stock one dry. The stock one is huge and very heavy.
It's at least half the rotating mass, of course it's going to dyno higher. Not like it really matters though, since no one races with a locked converter. Hell, even unlocked my aftermarket one dyno'd higher.
To help answer the original question better, don't worry about peak numbers. In my case, the peak numbers were higher, but look at the under the curve power, that's what matters, and you can see why a converter makes your car so much faster.
Old Nov 8, 2008 | 02:07 AM
jsteele90's Avatar
stalled autos rule the track not the dyno
