383 engine 700r4 trans combo
Old Mar 20, 2010 | 03:35 PM
badzss06's Avatar
Default 383 engine 700r4 trans combo
Perfect for a Third gen project
For sale
4 Bolt 383 Stroker fresh rebuild.
SCAT crankshaft
Probe Racing/Coast high perf rods and pistons
Comp Cams hydraulic roller cam
Comp cams retro fit hydraulic roller lifters with 1.6 around 570int 590exh lift
AFR 185 O-ring head gasket Comp Cams valve springs
Crane cam gold rockers 1.6
Comp Pro Magnum Push rods
Comp cams belts drive
Edelbrock water pump
pro products balancer
Edelbrock Victor jr manifold.
Holley Hp 830cfm carb
Moroso Fab valve covers with AN bungs
Hooker super comp Ceramic coated long tubes
Moroso oil pan and pick up
MSD distributor
Dynamic Racing 700r4
Hughes racing converter
Hughes deep aluminum pan
Valve body set up to run off vacuum for conv lock up
also have manual valve body new in box
heavy duty drum and bands
corvette servos
Inland empire aluminum driveshaft
Still in car hear it run and drive it.
$5500.00
